RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   sv27 6 cell (https://www.rcuniverse.com/forum/speed-electric-109/7341582-sv27-6-cell.html)
coop81 04-06-2008 01:19 PM
sv27 6 cell
could i wire 2 3 cell 2100 lipos in parallel to make 6300 in the sv27 or would i have any problems with run time or any different problems
ryan_t888 04-06-2008 03:27 PM
RE: sv27 6 cell
You may do that but it won't be the same as running 4s LiPo which is the norm.
Ryan
sonixx 04-06-2008 10:47 PM
RE: sv27 6 cell
sure u can, just prop up a little bigger and u'll still get decent speeds out of it
ctonez 04-07-2008 12:47 PM
RE: sv27 6 cell
ORIGINAL: coop81
2 x 3S 2100mah parallel = 11.1V 4200mah, not 6300mah.
I'd consider using a Low Voltage Cutoff if you are trying this, bigger prop can alter the amp usage...and it won't be super fast, but it'll work.
Make sure you don't connect the 2 3s packs in series by mistake...it'll blow the ESC and likely the motor too...don't ask me how I know.
