RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   lower kv motor (https://www.rcuniverse.com/forum/speed-electric-109/7637883-lower-kv-motor.html)
ormer 06-19-2008 01:25 PM
lower kv motor
hi a was wondering if i am correct that a lower kv motor should be able to swing a bigger prop then a hi kv
alloutcustom 06-19-2008 01:35 PM
RE: lower kv motor
That is correct, however it matters how much voltage you put through it. If it is the same voltage for two different kv ratings, the lower one will spin a bigger prop. What is your setup? how much kv?
ormer 06-19-2008 04:24 PM
RE: lower kv motor
1 Attachment(s)
well it is my boat that i was killing my esc in now my motor and my esc has arived
the motor is kb 4508xl 1700kv
the esc is also what was recomended a turnigy plush 100amp opto
going to run subsurface in a multi hul style boatit is about 36 inches long
