RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Nice Riggers? (https://www.rcuniverse.com/forum/speed-electric-109/7662207-nice-riggers.html)
FHHOBBIES 06-25-2008 11:36 PM
Nice Riggers?
I was looking to get a Rigger and was looking at this one... http://www.offshoreelectrics.com/pro...igged-insanity is it any good or what are some other options? Thanks.
detox 06-26-2008 01:23 AM
RE: Nice Riggers?
1 Attachment(s)
I am building the Rigged Insanity model and everything is going together verygood. I think the newer packaged kits will have the better updated instruction booklet.
First time out I plan on powering it using the Traxxas Velineon 3500kv brushless motor, hydra 120 esc, and 3s power.
FHHOBBIES 06-26-2008 06:42 AM
RE: Nice Riggers?
Very nice, I was thinking about a Feigao 7XL or 8XL with 4S 5000mah PolyQuest Lipo, 200A ESC. What do you think? What are you going to use for Hardware?
ryan_t888 06-26-2008 07:31 AM
RE: Nice Riggers?
I've personally raced against the designer of the hull and I can assure you it performs excellent. This rigger can easily get in to the mid 50mph range with a solid motor system and setup. THe biggest advantage I see with this hull is it can handle shop very well. As a comparison it handles chop a lot better than the SV even though the SV is much slower.
A 7XL, 4s LiPo and castle 120A ESC would work great.
Be sure the 4s LiPo consists of 2 2s packs wired in series. This way it will fit properly in the hull.
Ryan
detox 06-26-2008 12:23 PM
RE: Nice Riggers?
ORIGINAL: FHHOBBIES
OSE recommends Solinger hardware which is what I have purchased: http://www.offshoreelectrics.com/pro...prod=sol-hydro
Solinger recommends Hughey .125 flex cable with .130 teflon tubing: http://www.offshoreelectrics.com/pro...prod=hug-e1067
detox 06-26-2008 01:12 PM
RE: Nice Riggers?
ORIGINAL: ryan_t888
THe biggest advantage I see with this hull is it can handle chop very well. As a comparison it handles chop a lot better than the SV even though the SV is much slower.
Ryan
This is good to know.
CadillacDTS2001 06-26-2008 04:25 PM
RE: Nice Riggers?
solinger will work but is on the small side for the 7XL on 4s.
go for a speed master rudder and strut.
http://www.offshoreelectrics.com/pro...d=ros-21-strut
http://www.offshoreelectrics.com/pro...d=ros-mini-rud
FHHOBBIES 06-26-2008 05:13 PM
RE: Nice Riggers?
Great thanks for the good info guys!
