Ding in Hull
OK - I just checked and sure enough that plastic coupler/drive dog (piece of junk) bounced off the bottom of the hull when it broke - The hull is still sound although the paint chipped off a tiny bit on the bottom - Should I put a drop of Xpoxy Finishing Resin and sand it down good - or what is recommended - Thanks - Steve (I also posted this to my other thread regarding the lousy plastic drive part - (a correction to that post is - the dent in the ceiling was from something else)
RE: Ding in Hull
Could you post a pic or two of the damage?
By the way what hull is this. |
RE: Ding in Hull
1 Attachment(s)
It's an out of production now - Dolphin - here is the link - http://www.jethobby.com.sg/cgi-bin/e...w&pid=828&cid= Hopped up good ( or maybe not so good) - I am tring to get a wire drive for it - There are pictures in my other thread re this boat and I can't seem to upload another one - Thanks - It's not so bad - Steve
RE: Ding in Hull
If you use epoxy and use high grit sandpaper I think it'll be just fine. Just make sure that it'll be nice and smooth cuz its on a running surface.
| All times are GMT -8. The time now is 10:01 AM. |
