RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   HELP!!! (https://www.rcuniverse.com/forum/speed-electric-109/8099267-help.html)
mnavelski 10-30-2008 02:10 PM
HELP!!!
ive been lookin at a boat on ebay item #290252484982 but im not sure how to complete the boat can any one help me? thank you in advanse
ormer 10-30-2008 02:15 PM
RE: HELP!!!
when you say finish it is batterie needed and need choose placement of that
but i would say before you do anything to it is check over the whole boat first
looks like you going to need radio gear and batteries that is pretty straight forward
RC_Bob 10-30-2008 04:37 PM
RE: HELP!!!
If you were to get this boat I would recommend two 2s lipo packs (or a parallel of two 4s packs of 4200) and this radio system:
http://www3.towerhobbies.com/cgi-bin...I=LXNHS2**&P=7
My only big concern is whether the esc has a bec or not.
mnavelski 10-30-2008 05:13 PM
RE: HELP!!!
thank you, im going to but the boat and ill be back with some more Q's. thanks again
SV27dayton 10-31-2008 06:20 AM
RE: HELP!!!
please be more specific in your subject choice. HELP is hard to shearch on later should anyvaluble information be included in the thread.
mnavelski 10-31-2008 10:57 AM
RE: HELP!!!
sorry about that, thanks in advance for any future help.
pompebled 10-31-2008 11:23 AM
RE: HELP!!!
ORIGINAL: mnavelski
That: http://cgi.ebay.de/ws/eBayISAPI.dll?...ies%26_fvi%3D1
is the well known 25" mono that has been on almost every forum, you should be able to find a lot of info on it.
In order to run it, you'll need batteries and a radio set.
Mail the vendor and ask if the ESC has BEC; if not, buy a UBEC with the boat, more convenient than a seperate receiver pack, IMHO.
Regards, Jan.
Basstronics 10-31-2008 12:00 PM
RE: HELP!!!
Thats the same boat some of us have.
We have found that motor to be useless. I think theres 4-5 of us and nobody is running that motor anymore...
I ran mine with 60 Amp esc and 3S lipo. Running just a single 20C pack wasnt good...
The Run:
http://www.youtube.com/watch?v=DUSGTNvgtOQ
The death:
http://www.youtube.com/watch?v=ga_WxDgltBg
beware of foul language...
Its a good boat but that motor is just to small for it, thats the bottom line. For $120 its a good buy. I would sell the ESC off for about $45 and the Motor for $15-20 and then you got a prebuilt boat minus electronics.
Thats why I bought it also. I wasnt sure how to set the boat up and didnt want to risk messing a hull up.
mnavelski 10-31-2008 01:12 PM
RE: HELP!!!
thank you. im new to boats so i dont even know how to install the missing peices or anything but it cant be to hard. is there any direction and how tos to do the instalation or some sort of walk through for beginers. i just dont want to buy a generic boat out of the box and want to put the time into it and make it mine. thank you. matt
Basstronics 10-31-2008 01:58 PM
RE: HELP!!!
Im pretty new myself.
Its a good boat to start with if you want to do some work, which it sounds like you do.
Like I said the motor/ESC is just to small for the boat. it might work with a smaller prop around 64-36MM, but if you go for a bigger one like I did (42mm dia) it will kill that motor.
If you look at the Prince thread you will see the different setups.
One guy has a 36mm dia motor, runs 4S and seems happy with it.
I have a 28mm dia motor run 3S and I think its plenty fast.
mnavelski 10-31-2008 04:49 PM
RE: HELP!!!
besides the ESC is there any differance betwen the the boat from r2hobbies, and the boat on ebay # 290252484982? the one from r2 looks like it has some sort wood mounting plate in back and for the batteries in the middle part of the hull but does not have the ESC, and the ebay boat has the ESC but I can not determin wether or not the boat has those mounting plates or am i talking nonsense and i can buy those at a hobby shop? thank you. thank you.
Basstronics 10-31-2008 07:37 PM
RE: HELP!!!
Your seeing the different setups.
R2Hobbies boat uses the stinger type drive and has wood stringers run in it.
The Head Of the River Boat uses a strut and has seperate mounting of motor, servo and battery.
Personally I went with the R2 Hobbies boat as I wanted the stinger drive and I liked the stringers and mounting locations.
