cheap brushless setup for mini-c
hey i need help findin a cheap way to make my proboat mini-c faster. anyone know a good cheap brushless setup, also need a new servo.
RE: cheap brushless setup for mini-c
Anything you can use in the mini rio you can use int he mini c. I have both and both are brushless. .
Here you go. You wont get any cheaper or better than this for the money. Everything here will work in themini c.
You should order everything you need at once from Hobbycity because shipping is like 25.00 no matter what you get. Get at least 2 or 3 batteries. You also need to make sure the batteries are as small as you can get sizewise. Then get some deans connectors and some .047 piano wire. Battery http://www.hobbycity.com/hobbycity/s...y_Pack_w/_Conn charger http://www.hobbycity.com/hobbycity/s.../Charger_2S~4S Motor http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4201&Product_Name=HXT_28 35_(380S)_2700kv_Brushless_Inrunner ESC http://www.hobbycity.com/hobbycity/s...Simple_40A_ESC |
2many,
Do you have any video posted of that mini running? |
No. Everything around me is frozen. Once everything thaws I will post vids of my brushless Mini c and brushless mini rios. Its very fast though.
Cool. That sounds like a pretty inexpensive but rewarding project.
It was very inexpensive to be able to outfit 3 boats for about 100.00 total was great.
hey do u know a good servo, i would like something bigger. any suggestions??
I use a hitec servo. The stock one works fine though
| All times are GMT -8. The time now is 06:40 AM. |
