RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   Hydromites, yes two! (https://www.rcuniverse.com/forum/speed-electric-109/8342681-hydromites-yes-two.html)
Basstronics 01-10-2009 04:17 PM
I decided in the fall I was going to build two Hydromites over the winter. I built one years back freehand. it turned out good but it never was finished. So here I am...
This time around I found out about Lazer Works that has "short kits" of the hydromite. Basically the woods precut except the larger sheets of square balsa/ply. Eddy got me my order in record time. http://lazer-works.com/list.html and its under $22 for the kit, well worth the $.
The power source is the same as Dr Jets small stuff. The 3000 KV small outrunner and the 30A Mystery ESC. I dont have a battery pack or rx picked out yet...
Heres some build pics:
This is the wood thats been laser cut.
http://i38.photobucket.com/albums/e1...e/100_0106.jpg
Wood trimmed and sanded smooth on the edges:
http://i38.photobucket.com/albums/e1...e/100_0107.jpg
The start of the skinning. Beware you need 1 right and 1 left!!!!
http://i38.photobucket.com/albums/e1...e/100_0108.jpg
Next step, the small sponson former:
http://i38.photobucket.com/albums/e1...e/100_0109.jpg
Small size issue. The slots not big enough for the thickness of the material. You need to sand towards the center. I used a needle file and was done quickly.
http://i38.photobucket.com/albums/e1...e/100_0110.jpg
Assembled:
http://i38.photobucket.com/albums/e1...e/100_0103.jpg
Basstronics 01-10-2009 04:18 PM
RE: Hydromites, yes two!
Both frames:
http://i38.photobucket.com/albums/e1...e/100_0111.jpg
I need to work on the exact position on where to drill/run this motor mount:
http://i38.photobucket.com/albums/e1...e/100_0104.jpg
Hardware... I started off making my own but thought the hell with it. I want these boats to look NICE. So I shucked out a mere $34+ shipping per harware set. Including rudder, strut, flex shaft and all drive components EXCEPT coupler:
http://i38.photobucket.com/albums/e1...e/100_0101.jpg
I purchased the hardware from "Head of the River" guy on E Bay. He seems decent but he got my order wrong. I was supposed to get one red and one purple hardware set. Instead all silver... Its not a major problem just more of a disappointment. However he did ship very fast!
http://stores.ebay.com/Head-of-the-River-RC-specialist
More pictures to come.
BACKEMF 01-10-2009 04:58 PM
Nice !!! I didn't know I could get a short kit lazer cut!!! I cut one by hand years ago too and sold it... miss it too...
So I can order one from the above link?
Nice hardware, I was thinking the same stuff!
I'd skin it in 1/64 ply, very rigid... Double it up on the inside where you can....
Cool!
.....I was also one, if not the first to skin the inside of the sponsons in 1/64 ply... I see it caught on...lol
Basstronics 01-10-2009 05:01 PM
Ya Lazer Works was awesome!
The shipping seems a bit high because of Fed Ex, I ordered another kit and some motor mounts I drew up and the shipping was only $4 more or so...
If you want to run the small mystery Outrunner I have drawings of the motor mount. Fits good with a quick buzz out of the mounting holes. Allows for good cooling and is still rigid.
BACKEMF 01-10-2009 05:15 PM
Thats cool, I still have a couple inrunners around I can use... A mega 1615 3000KV and a chinker 3600KV 2pole...
Remember if you want to use Graupner threaded props, just drill out the inside brass and plastic with 7/64" drill and better yet use a 5-40 tap (for Octura threads) or whatever the thread is on the "Johnny" H of T R Specialist... stub....
Works slick! cheap props too!
