RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   War Ship (https://www.rcuniverse.com/forum/speed-electric-109/8834603-war-ship.html)
chickendog 06-08-2009 04:03 AM
War Ship
Hello,
I am looking to try and upgrade one of these war ships. However, i had one (the carrier)before and the hull was glued together and i couldn't open it. If anyone have these please let me know if they can be opened.
http://www.bananahobby.com/1108.html
http://www.bananahobby.com/1133.html</p>
headhunter23 06-08-2009 09:12 PM
RE: War Ship
If they're like every other glued together hull(ndq) some acetone will work but it takes a while and is a huge pita to do properly, I normally get frustrated half way through and start slicing with exacto. Anyways with acetone or some other harsh chemical u can actually soften the abs plactic of the boat(which isn't good), so becareful and more patient than I am. Properly, is to be watching all the time and literly put on a drip or two, then start working the glued area apart after 5 min or so. Running a large area doesn't seem to work, the acetone seems to ruin the plastic if on too long etc. Essentially bring some beers but not enuff to say screw it and finish the rest o boat by forcing apart.
Others might have better ideas, i know it works but like I said u need patience, more than Ihave.http://www.rcuniverse.com/forum/js/f...wink_smile.gif
chickendog 06-08-2009 09:59 PM
RE: War Ship
1 Attachment(s)
I found out i am not a patient man 8( Ihope the War Ship, 20" would be easier to open.
headhunter23 06-09-2009 05:42 PM
RE: War Ship
dude, do what u need to inside hull, glue all backtogether(even broken top), sand(takes long time and patence work your way up to 1000 grit, i would go 2000) and repaint, u won't notice ya fubared it.
Ivan.
