rule of thumb
i was wondering if there is any way to approx the loaded rpm based on motor size, unloaded rpm, and prop size/pitch</p> |
RE: rule of thumb
Typically around 70-85% of the unloaded RPM using nominal voltage for LiPo's under a moderate load. It does vary quite a bit, even outside of this range depending on several factors.
Ryan |
RE: rule of thumb
thx that does help alont, btw jus curious what are some of the other factors
RE: rule of thumb
List of factors - some minor, some major
- prop pitch - prop diamter - prop efficiency, - Driveline efficiency - Strut Depth - hull Drag - Hull Type - motor efficiency - Amount of Load placed on motor - LiPo C rating - LiPo Capacity - LiPo Voltage Drop - ESC/Wiring efficiency - Water Conditions and several more Ryan |
| All times are GMT -8. The time now is 07:54 PM. |
