RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   seaking 35a esc program help needed (https://www.rcuniverse.com/forum/speed-electric-109/9000345-seaking-35a-esc-program-help-needed.html)
enjoymentboy 08-08-2009 04:28 PM
I have this esc programmed now with the help of the programming card but it seems to be hit or miss if I can get the motor to start or if I just go into program mode again. The instructions that came with my esc are a bit ambiguousat best. Can anyone help me with the proper startup sequence for this esc? Tx on. Batt plugged in. 2 beeps to confirm my cell count and then throttle to start. is this correct?
Thanks.
enjoymentboy
LENYLOW 08-08-2009 06:13 PM
RE: seaking 35a esc program help needed
I have the 90amp version for my 25"mono, from what i can tell by reading through the instructions i have, is that your doing everything right for the " Normal start process"
So not sure whats going rong, have you set the full throttle setting on the transmitter? this has to be done before the normal start process will work properly.
enjoymentboy 08-09-2009 11:40 AM
Do I have to set the throttle position every time I reconnect my packs? If so that might explain my problem because I have NOT been doing that. I'll try that then. Thanks.
LENYLOW 08-09-2009 01:21 PM
on the instructions i have it looks like you should only have to do this once unless you change the transmitter.
wouldnt hurt to just try re-setting it though. These instructions arnt all that clear either, probably the same ones
you have.....
enjoymentboy 08-10-2009 02:16 PM
sounds like we have the same instructions. so far it hasn't worked for me to not do the thorttle position setting first but it works for me when I do that, so I may as well continue. Thanks. :)
