Hor 32' Apparition
1 Attachment(s)
will variant A work to improve hull stability, or is it variant B only.
(varient A is just a 2mm styrene strip glued to the inside of the sponsen) Varient B looks like it can be made out of decorative wooden moulding, i've seen triangular cross-section before; in DIY storeshttp://www.rcuniverse.com/forum/js/f...sn/thumbup.gif |
RE: Hor 32' Apparition
I would go with "B" since it is truer to real life and similar to Hanspeter's cats.
It should improve stability all around. Try to mount the drives as low and to the center of the hull as possible. See a Thread started by "RULL" (aka Serge) and he has done this mod to his HOTR cat. It is approx. 1/4" x 1" and the angle ends up approx. 14 Degrees. |
ORIGINAL: BACKEMF I would go with "B" since it is truer to real life and similar to Hanspeter's cats. It should improve stability all around. Try to mount the drives as low and to the center of the hull as possible. See a Thread started by "RULL" (aka Serge) and he has done this mod to his HOTR cat. It is approx. 1/4" x 1" and the angle ends up approx. 14 Degrees. mine is single screw , but i can still get that drive close to ``in line`` with the centre line of the hull length, because i definitely dont want the propshaft hanging down at 3 degrees, or she'll lift her bows....this means that i might have to mod the rudder assy, by lifting it up 2 degrees, whatever the case, i'll be able to suss this out somehow |
It will make the hull more stable, single or twin drive.
Rudder is always mounted staight and centered. |
ORIGINAL: BACKEMF It will make the hull more stable, single or twin drive. Rudder is always mounted staight and centered. there's loads of time till next summer and it's far too cold until about the end of April , so there's no hurry to get on the water! |
variant A is out of sense. The hull with A will be able only to go straigth and can`t turn. The A is the same like without modification but with additional water resistance.
thanks
variant B it is then, right i'll need to pop into B & Q this weekend, take a look at their wood mouldings, i've definitely seen triangular cross section by about 8ft long, but i cant remember where! |
hey malcolm
try in the DIY section LoL under decorative mouldings |
ORIGINAL: nick 30 hey malcolm try in the DIY section LoL under decorative mouldings |
http://www.youtube.com/watch?v=YkWW3...eature=related
this video looks quite good, she looks fast too; considering the water is choppy. ...... 7T motor it's the first video of her where she actually looks 32'' long, in others she only looks about 27'', when i told that bloke in Germany that i was going to spray mine black, he said; ``never black, she wont show up well enough, always go for light and bright colours``. |
he must've been watching one at night with ni lights then :-)
could always put some day glow stickers on just to make sure |
the hor Apparition 120 amp ESC ( Astec), is right on the limit for the 580/7T motor, it therefore isn't good enough; so that will need upgrading
if i go for this 580 motor, i may as well get the hull only; because all the rest is not up to it, decisions...........decisions !!!! |
go for the hull mate, that way, you can get everything you need in whatever sizes etc
i'm sat scetching some ideas for an outrigger plan, got the general plan just need to decide how tall and wide the tub will be, i'll have to design it round the size of the battery i'll use and make it a certain height |
yes
i can get the hull on the 1st JAN, i need to start building something soon because i'm getting bored out of my mind. http://www.astecmodels.co.uk/catalog...products_id=93 that motor will need the 48 dia cooler |
im using 2 of them on my 12XL motor, i connected 2 ends together so inlet goes one side and into the other and through the outlet, the jacket i bought is to short and i cracked it, i put superglue inside and out then wrapped some hatch tape around the inside and out
1 Attachment(s)
that looks about right for its colour, i'm actually interested in buying the Hyperion P51 electric Mustang aircraft, but i'm scared of crashing it, i think a fast cat is far safer and less costly, after all; it can only flip over!
nice looking boat
had my mini mono on the water today, it states that this boat is self righting but all it did was an impression of a dead dog with its feet in the air i want to put the battery over the keel line in roughly the same place it was on the left side but dont know if to move the motor forwards or backwards |
ORIGINAL: nick 30 nice looking boat had my mini mono on the water today, it states that this boat is self righting but all it did was an impression of a dead dog with its feet in the air i want to put the battery over the keel line in roughly the same place it was on the left side but dont know if to move the motor forwards or backwards i couldn't get Magin 1 to self- right either, she just lay upside down in the bath, the water wouldn't even flood her chamber! i'll buy a cheap fishing rod for the hor 32'' |
sounds good to me mate
im just wondering wether to add trim tabs to my mini mono, was thinking of moving the motor forward by 3 1/2" and mount the batt on the keel line but it does meean a new shaft and stuffing tube |
ORIGINAL: nick 30 sounds good to me mate im just wondering wether to add trim tabs to my mini mono, was thinking of moving the motor forward by 3 1/2'' and mount the batt on the keel line but it does meean a new shaft and stuffing tube |
i have tried but have had no answers yet
i just made a phone call about the RC Hyperion Mustang P51 D, it's not recommended for a first aircraft, he said i must learn to fly a trainer first! i suppose he's right, he said its too lively, it would crash strait away; if you're not used to the controls.
i thought so anyway, oh well; i'll get the Hor apparition instead, hull only. |
my first plane was hawker sea fury, polystyerene and went pretty good, but then i have flown a couple of real planes and a heli
ORIGINAL: nick 30 my first plane was hawker sea fury, polystyerene and went pretty good, but then i have flowna couple of real planes and a heli |
start with a micro heli and work up, thats what i did in the end, i still got it actually just dont use that much
| All times are GMT -8. The time now is 04:41 PM. |
