RCU Forums
-   Speed - Electric (https://www.rcuniverse.com/forum/speed-electric-109/)
-   -   super vee 27 (https://www.rcuniverse.com/forum/speed-electric-109/9632683-super-vee-27-a.html)
bdobson 04-02-2010 04:33 PM
super vee 27
hi guys have a super vee 27 brushless not vary smooth in water at a lower speed but at full tilt no probs other that going right i think ? or left i no it has to do with the fin only on one side but trying to make it plane out at a lower speed ie the rear lol drops front goes up have two 1600 nimah batts will lipo fix this i know when i started charging at 5 amps was much better thanks in advance
srt10 04-02-2010 06:48 PM
RE: super vee 27
oh man, you should get some bigger batteries ;)
ryanwilson277 04-02-2010 07:14 PM
RE: super vee 27
i have the same problem when i go strait the boat wants to turn to the right kinda hard and im working on it and if i ajust the steering trim to go strain no watergets in the pickup
SV27dayton 04-02-2010 07:27 PM
RE: super vee 27
You should use full throttle to take off regardless. Surface drives need to produce alot of thrust to get the boat on plane. Ive never heard of anyone having success with that small of battries. Better bats will help but not if you are trying to plane at part throttle. If you use a big diameter 2 blade like a 642 octura or a CF45 plastic prop you will come out of the hole much better but they are harder on your batts.
srt10 04-02-2010 07:34 PM
RE: super vee 27
ORIGINAL: ryanwilson277
use a point file to gently open up the inlet hole
jigawatt 04-02-2010 07:57 PM
RE: super vee 27
He definitely needs batteries that are capable of delivering the amperage that brushless demands. Where did you find NiMH packs that were 1600??? I can't really even think of NiCd cells that sold on the market at 1600 mAh
srt10 04-02-2010 09:01 PM
RE: super vee 27
I think you can even get 1200mah packs still
asupervee72 04-04-2010 10:00 AM
RE: super vee 27
here are a couple options, open up the stock rudder with a file (which i think weakens it), ditch the stock rudder and use a transom pick up ( much better water flow), as for getting your trim strait, are you familiar with prop modding at all? sounds like you need to spoon out the tips of your blades a bit so that the thrust is directed in a more concentrated cone, I use to have that problem with one of the bigger props i ran in the past
srt10 04-04-2010 10:45 AM
RE: super vee 27
I used to use a second pick up for cooling but for me I found that using a point file in the stock rudder pickup works best.. much better cooling and it does not cost anything, also less drag
bdobson 04-04-2010 05:16 PM
RE: super vee 27
ah sorry guys not useing 1600 mah im useing 4200 mah packs as far as my level of work i can do on the boat is not much but learning as i go everthing factory prop and so on got it because my grand son likes to watch it now i want to make it nor so he will be able to take over in 2 years i hope
