is this right?
hi guys
ok i want to get more speed out of my boat she a big one , i need more speed so i need to cut weight and going to go with smaller props i would like to know if this will work in place of the two gel cells at 12 volts 7 amp each the esc are two of them and will take 24 volts each and 80 amp con from modelcontrol two of theses for each esc and motor and the hook ups ,that should give me 14.4 volts and 10 amps ? thanks would be series right? thanks rye http://www3.towerhobbies.com/cgi-bin...&I=LXSFS8&P=ML http://www3.towerhobbies.com/cgi-bin...?&I=LXXKN0&P=7 |
| All times are GMT -8. The time now is 10:29 PM. |
