FLOOD CHAMBER DIMENSIONS REQUIRED
CAN ANYONE HELP ME WITH THE DIMENSIONS FOR A FLOOD CHAMBER I WANT TO PUT IN MY HOR 25" MONO / SAME AS PRINCE 25"..CHEERS</p> |
RE: FLOOD CHAMBER DIMENSIONS REQUIRED
hello mate, hows the the other 33" mono hull
was thinking of using a floodchamber in the 29 mono, i was going to make it from transom to just past the hatch, 1" wide from the left side hatch and straight down to the bottom of the hull so i suppose 15" long, 3" from hull side wall and 3" deep |
HI NICK, ALL THE BITS SHOULD BE WITH ME IN THE NEXT FEW DAYS FOR THE 33",THAT WILL RUN 6S,THE FLOOD CHAMBER IS FOR A SECOND HOR 25", THAT I WILL RUN ON 4 S LIKE PHIL, THEIR IS A MOTOR AND A FEW BITS ON ROUTE FOR THAT, PLUS SOME BITS FOR MY KOS CAT, SO I THINK I HAVE A BIT ON MY PLATE AT MOMENT.....AL
you certainly do al
| All times are GMT -8. The time now is 07:44 AM. |
