Looking for 8mm - 1/4" stepped prop shafts ( RCMK or MTC )
CA
Like header states ... seeing if ANYONE these shores has any inventory of the H.D. 8mm prop shafts stepped to 1/4" having a 1/4" cable hole in the other end. ( need 1 .. would by 3 )
Worst case will have to source from Europe or Asia ... figured asking here first
RE: Looking for 8mm - 1/4
Scott,
I should have two complete RCMK new flex shafts. They use a special drive dog and I might have one of those also.
I will look tomorrow.
Thank you,
Daniel
Thank you,
Daniel
CA
ORIGINAL: idocdave09
Like pictured here (just the shaft part)
http://www.whhonline.com/PhotoGaller...ductCode=RMB95
Shaft I'm looking for are 1/4" at prop shaft, then step up to 8mm for the entire length of bearing surface then have a 1/4" female hole in the end to SOLDER your cable into ... which will be in my case a Square end cable running in a square drive collet at engine.
contact arrowmodelsport.com he would make you one but he's in the uk ! does a nice stinger and billet engine his site is new and has ony got an engine on it at the moment
NY
WHH has them that are 5/16 at one end for the cable to be soldered it the rest is turned down to 1/4 with 1/4 NF thread for the prop nut
ORIGINAL: Scott Schneider
No, that type is a reverse square drive 1/4 cable still requiring compression collet at engine.
CA
We need the larger diameter threw the bearing areas, running 75/85 mm props 1/4" bearings are getting beat to death, thus WHY wanting the bigger 8mm stuff
Shaft I'm looking for are 1/4'' at prop shaft, then step up to 8mm for the entire length of bearing surface then have a 1/4'' female hole in the end to SOLDER your cable into ... which will be in my case a Square end cable running in a square drive collet at engine.
CA
Ah, the threaded on drive dog shafts .... yea thats the basic set-up. Tho looking for shafts only to solder sq drive cable into.
Looks like some of my European buddies are willing to set me up with some parts and pieces like shafts, bearings, struts etc better suited for twin abuse duty ..... just have to figure out what selection of parts shared so far best suits what I'm after.
