SEEKING PROP RECOMMENDATIONS FOR EXPRESSCRAFT THUNDERBOLT W/ QUICKDRAW HT
IL
GREETINGS IF YOU HAVE ANY PROP RECOMMENDATIONS FOR MY PARTICULAR SET UP WHICH IS :
26 CC QUICK DRAW HT / WITH STEEL PIPE
BONZI INLINE STRUT/ RUDDER SYSTEM WITH THE DUAL WATER PICK UP ON RUDDER
BONZI CLUTCH
ANY RECOMMENDATIONS WILL BE GREAT APPRECIATED
THANK YOU
BONZI CLUTCH
THANK YOU
IL
RE: SEEKING PROP RECOMMENDATIONS FOR EXPRESSCRAFT THUNDERBOLT W/ QUICKDRAW HT
THANK YOU FOR YOUR SUGGESTION. THE PROP I HAD GOOD PERFORMANCE WAS A OCTURA 470 , I'M PREPARING TO TEST WITH A 7016 X 2 AND I ALSO HAVE A 6518 X 3 TO TEST ALSO. WHAT DO YOU THINK ABOUT THESE SELECTIONS
You will notice the 3 blades will give you more lift than the 2 blades....but give them a try and see how they work. Might work with your set-up. I like to test with GPS and tach installed which also helps me know which direction to go for best rsults.
