Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Flex Shaft and how accurate but should be?
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 06-05-2012, 08:01 AM
Jackercsweden
Jackercsweden's Avatar
Default Flex Shaft and how accurate but should be?
this small gap and I would need to fix this or what??
Old 06-05-2012, 08:07 AM
BH_Trade
Default RE: Flex Shaft and how accurate but should be?
Not the best pic but yes I would recommend fixing that for sure!
Old 06-05-2012, 02:06 PM
glennb2006
I would realign that to be a smooth in and out into the collet. Should be easy to do, either shim the engine across as needed or if you are using a tee bar shim the prop tube across.
Glenn
