Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
swashdrive jetboat
Speed - RC Gas Boats Discuss gas RC boats right here!
swashdrive jetboat
Old 06-10-2012, 10:05 AM
phillio35
Default swashdrive jetboat
hi all just in the process of trying to get a drive for my davette jetboat but mhz havent got any has any one got one for sale or is there an alternative
Old 06-10-2012, 10:33 AM
Mario Giordano
Default RE: swashdrive jetboat
Hello, they has just added their new drive jet-4 and also have 10 pieces in stock, look here http://shop.mhz-powerboats.com/categ...-22/Jet-4.html
Regards
Old 06-10-2012, 12:19 PM
infinityteg
the other option is the Jettec unit which should be out very soon.
Ive seen on a german forum that someone has one already
http://www.jettec.co.nz/#/shop/45634...Jettec/2208552
cheers
steve
Old 06-10-2012, 12:35 PM
phillio35
hi mate ive just ordered a hobbyking jetdrive any views on them
Old 06-10-2012, 02:23 PM
HendricX
HendricX's Avatar
The Hobby-King is a piece of s***.
[link=http://www.jrcbd.com/showthread.php?t=63625]Thread on Jim's[/link] from Lohring Miller :
Hobby King Jet Pump
I recently purchased a Hobby King jet unit and was very disappointed at the quality.
For a start the ball bearing bore was .015" (.38 mm) out of round. As a result the inlet halves wouldn't clamp together.
The screw on one side of the bore was stripped. After helicoiling the two screw holes on either side of the ball bearing housing ,
to #4-40, I very carefully rebored the bearing bores to .001" (.03 mm) undersize on the bearings.
This also aligned the bearing bore with the nozzle mating surface. However, this lead to binding on the impeller shaft.
A check showed that the shaft had .005" (13 mm) or more runout depending on how it was held.
I held it on its center and the stator bearing surface which gives the least runout.
The shaft was also undersize, so a new shaft was made. The impeller has almost .040" (1 mm) clearance.
Since 10", full size impellers often run less than .010" (.25 mm) clearance, I would expect this to seriously effect performance.
I trued the impeller and the stator (They were a few thousandths out of round with their bores.),
drilled and tapped the stator for a grease fitting, and bored the nozzle out a little for a wear ring.
It is .080" (2 mm) thick UHMW held in with a press fit and CA.
There were other issues with play in the steering and trim nozzle as well.
See the discussion on the [link=http://modeljetboat.com/forum/index.php?topic=652.0]Model Jet Boat forum[/link] for others' solutions that I also used.
The NZ one is almost a work of art.
Old 06-11-2012, 09:28 AM
phillio35
how long does mhz take to get things in jetdrive3
Old 06-11-2012, 10:12 AM
Mario Giordano
What do you mean? i don't understand your question. In their webpage you  have all the data, price, shipping time, stock, description etc, the jet power 3 is not in stock, but  you should drop a message to Shirley Bombelka, she will give you all the info you need.
Regards
Old 06-11-2012, 10:20 AM
Ron Olson
Ron Olson's Avatar
ORIGINAL: phillio35
Not good so far, poor fitting, sloppy workmanship and stripped threads. Lotza luck if you have to return it as their service isn't very good. Whatever's wrong they'll try to blame you for.
Old 06-11-2012, 11:07 AM
phillio35
hi mate got onto them hk to see if they can cancel order waiting for reply ordered last night
Old 06-11-2012, 11:17 AM
qdemon
Hi Mate
do yourself a power of good and phone Mhz direct, they will probably answer the phone in german but most of them speak english, if you ask for sherly ( she speaks perfect english and knows what she's talking about ) shes works untill 2pm weekdays and will certainly help you out, great people to deal with.
Bob.
Old 06-11-2012, 11:45 AM
phillio35
hi bob thanks i will try to call tomo
Old 06-12-2012, 10:54 AM
phillio35
just got money back on hk pump and ordered a pump from jettec nz it looks the dogs b.......s
Old 06-12-2012, 02:02 PM
HendricX
HendricX's Avatar
Good decision. ;-)
Old 06-20-2012, 12:25 PM
phillio35
hi just a start to my build dana sent me a picture of boat out of mould
Old 06-20-2012, 03:02 PM
HendricX
HendricX's Avatar
Something better as a post-stamp would be nice to be able to evaluate.
Old 06-20-2012, 03:11 PM
KENDOG689
KENDOG689's Avatar
If it,s a Devette,no need for a bigger pic.Quality all the time.
Old 06-21-2012, 05:05 PM
Dana W
This photo should be bigger then a postage stamp
Old 06-22-2012, 05:41 AM
phillio35
ha ha thanks for that dana dont no what happened there boat looks good mate
Old 06-22-2012, 06:01 AM
Dana W
LOL , thanks Phil . It'll be shipped to you today . Just waiting for the Post Office to open .
Dana
Old 06-22-2012, 12:44 PM
HendricX
HendricX's Avatar
Did not expect anything else ... flawless ... as ever Dana. !
Old 06-23-2012, 06:28 AM
phillio35
will keep updated when every thing gets to me and i start the build guys
Old 06-25-2012, 10:06 AM
phillio35
hi all radio box all done and engine all ready to be placed in davette sprint boat when she gets here
ID:	1775621   Click image for larger version
ID:	1775622   Click image for larger version
Old 06-25-2012, 05:51 PM
glennb2006
Nice and tidy. You might find the engine has a problem with the carb cover on, if it starts a kind of surging on and off behaviour when running at high revs, take off the cover and try it.
Let me know what you think of the Jettec unit, Adam seems to do nice work.
Glenn
Old 06-30-2012, 12:18 PM
phillio35
hi all just update on buid got boat today waiting for pump from jettec
ID:	1777224   Click image for larger version
ID:	1777225   Click image for larger version
ID:	1777226   Click image for larger version
Old 07-01-2012, 03:59 PM
HendricX
HendricX's Avatar
Nice solution with that bend-up manifold.
Not MY choise ... I would put the exhaust into the nose ... so nothing protruding the stern.
Obviously you've found a good TIG-welder .. so make that exhaust a 'wrapped-arround' , (Mathe-style)
then it's even shorter.
Ha ha ... a J&G into a squirthull ? Did you want to scare some people ? ha ha
