54" Bonzi Fountain
FL
RE: 54
Depends a lot on your setup and how much your motor will pull. In general if your CG is is high then a low lift prop and vise versa. a low CG percentage than a high lift prop. This is very general and doesn't always apply. The best I can say is find a fellow boater and try some props until you know what your boat likes. Contrary to what some may say, there is no special rule.
