Gear vs flex-shaft for outboard drive? Which is better?
NY
I recently purchased one of Dom's 1/4 scale Miller's Legend F1 tunnel hull boats, and I'm looking for an engine/motor mount. I'm not sure how I'll power the boat - I could go electric or go gas. Hence, a mount should ideally accommodate both. Dom mentioned that his YPC Enigma camber mount would, and I suspect that mounting a motor on a Lawless leg wouldn't pose too much of a problem either.Any other leg options out there?
So, here's the big question: do I buy a leg that usesshafts/gears, or do I get one that uses a flex-shaft? Which is the better way to go? Dom obviously knows what he's talking about and he made some good arguments in favor of flex shaft drives - among them the fact that they'd be less prone to breakage if Idecide to go electric. Still though, something about gears seems more reliable and hassle-free to me. Ido not want to be replacingflex-shafts(let alone going swimming in polluted water to retrieve my boat if one breaks). Other than MHZ, are there any other gear-driven outboard legs out there?
Your opinions would be much appreciated.
Dom, if you're reading, hope you don't take offense - Ijust like gathering other opinions!!
NY
RE: Gear vs flex-shaft for outboard drive? Which is better?
ORIGINAL: martno1fan
Flexshaft setups are far more reliable than any geared setup .
Mart
Mart
Yes exactly right scale looks,outdrives are stunning bits of kit but do not hold up to regular hard running.I suppose it depends on what you have planned,if your only an occasional boater and you want scale looks they work fine.
You say you were offered some advice by Dom on what to use on his hull ? well id say listen to it he knows what hes talking about.
Mart
Mart
mas3ydds,
Strange, I have not receive your email reply on the older design tunnel you are interested in. No matter.
There are other brands of geared lowers in the market. Arrow Shark and 2brothers. Contact Eddie de Vries for a set of lowers with flexi shaft which has a very stream lined torpedo.
NY
ORIGINAL: Body Guard
mas3ydds,
mas3ydds,
Send me an email about how to purchase the hull from you, when you get a chance.
Geared outboards have come along way since the lawless leg become available. I have one of Dominic's legs on his Hull and it goes really nice. I'm sure if you put a geared leg on Dominic's Hull it brings is to close in.... his hull was designed for a flexishaft outboard which generally have the prop further away from the transom.
has anyone bought a MHz outboard yet? They look a nice bit of kit for the money.
TX
saw a arrow shark outboard drive run this past weekend, ran very well had issue with swivel pin coming loose other than that no pro0blems.
I am running ypc new outboard drive and I like it very well
thanks,
jim pelezo
Odessa,tx
