Altitude
Altitude
Hi All, If you had a boat tuned at sea level and travelled to a site at 1000ft, would this change the engine tune and what way? My guess is it would run rich. I will be travelling to a meeting next month and would like to know what I may have to do.
Cheers
Cheers
It would run rich due to a thinner air density at the higher elevation. This is where a flow meter comes in handy. It will let you set the needle so that the engine "thinks" the air is the same. Just an FYI, AIR TEMPERATURE does the same thing as density. Warmer air NORMALLY ACTS thinner than colder air, requiring a leaner setting than the colder air would at the same location. This effect is much more pronounced in a nitro powered boat than in a gas so only going up 1000ft may make resetting the carb unneccesary
Thanks for the reply, I am running gas boats, should have said so. Its just a get together and did not really want to adj the carbys if I did not have to as it took a while to get the pipe and carbys set, as I run at sea level.
Cheers
Cheers
A thousand feet??? That's merely a hill! You will only need to lean down a wee bit if that. Maybe a smaller prop. I run at 5120ft. The air is a lot thinner up here. Carb settings are pretty much the same as down there, just a bit leaner. Because the air is thinner, the motors don't make the power they do at sea level. Smaller props are needed up here also. A thousand feet! HA!! Brian
Cheers
Andrew
I've bought boats from both Sydney and Brisbane and they didn't need any playing with.
I just run half a tank then I check plug color and that's about it for me in Canberra.
jim
ps are you going up on Friday, I'm planning on going up early Saturday as I'm working in Sydney that week
so I won't get home until late Friday night.
jim
Andrew
jim
jim
Cheers
ON, CANADA
1000 feet shouldent make much difference unless your right on the edge with tunning i run at two different spots and the difference is abouta 1000 ft find i need to make bigger changes due to temp than altitude
Cheers
