Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
ZippKit wood EASY VEE 46 inch Build
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 08-02-2016, 09:54 AM
Team Lucas
Originally Posted by Hydro Junkie
Glad to be of service. I just think back to some of the "questionable" things I've seen beginning builders try, me included many years ago. I figure if I can help others to prevent them from making some of the mistakes I made over the years, so much the better
I agree with newbe mistakes, but like you I built boats years ago, its just a lot different now for me. Things change and new/better ways develop after 15 to 20 years
Old 08-02-2016, 01:57 PM
Ron Olson
Ron Olson's Avatar
Klass-Kote is very similar to the old K&B Super-Poxy. Take it easy on the spraying as it can be watery. do some spray testing on something first before hitting the boat with it.
Old 08-03-2016, 09:47 AM
Team Lucas
Thanks Ron and was planning on trying it on scrap 1st. have you used Klass Kote befor, they say 1 part paint 1 part crystal and 1 part epoxy thinner.
Old 08-10-2016, 03:10 AM
Team Lucas
Lots of holes
all hardware mounted. Deciding on what radio box to use.
All that's left is radio box, top of boat, and painting, plus odds and ends
ID:	2176333   Click image for larger version
ID:	2176334   Click image for larger version
Old 08-10-2016, 10:02 AM
Ron Olson
Ron Olson's Avatar
The best advice that I or many others would give you right now, throw away that streamlined prop nut unless you like buying new props. Your cheaper option is to place a thin slice of your silicone tubing between the nut and prop as that will work as a lock nut if you feel the need to keep it.
With the swivel on the rudder arm, it's not made for 4-40 rod so you'll have to drill it out a little.
Old 08-10-2016, 02:46 PM
  #31
Hydro Junkie
Hydro Junkie's Avatar
Is that a gap I see between the bottom panels and transom? Before you prime and paint the hull, that needs to be properly filled. I'd recommend a slow curing epoxy(I like West Systems myself), mixed with silica fibers, as a filler since this is a structural repair. Don't use microballoons in this case as they are only good for making fillets in non-structural locations.
Old 08-11-2016, 12:32 PM
  #32
Team Lucas
that prop nut is a joke, I agree, will be putting on a locknut then the bullet. as for the rudder, I don't trust the swivel connections, have 4-40's with clip connections, just have to thread one side once I cut and size it. Swivel just came with rudder, will do pic's of linkages and radio box once done with them. thanks for the input.
Old 08-11-2016, 12:44 PM
  #33
Team Lucas
It is a 2 piece transom inner one is epoxied to the hilt. I was planning on filling that outer gap with 30 min epoxy. As in the picture you can see a hole for a self balier, that I epoxied in after not liking it there. BTW I didn't not know about micro balloons only being a filler more then strength, wonder why they tell you to strengthen the engine rails with it. Thanks for the input
Old 08-11-2016, 03:25 PM
  #34
Hydro Junkie
If you check out this chart, it shows the 407 Low Density, a microballoon mix, being used for surface filling and light structural. Any time I'm filling gaps or need thicker epoxy, I use the 406 colloidal silica fibers since it's more of a structural filler than microballoons. You might want to consider using the 404 or 405, instead, for engine rails
Old 09-18-2016, 07:04 AM
  #35
Team Lucas
Sorry its been awhile since I posted. too many projects going on at once. Well hull finally done and ready for primer.
ID:	2181397   Click image for larger version
Old 09-18-2016, 01:52 PM
  #36
Team Lucas
klass kote primer layed down great! showed a little imperfections I need to take care of, other then that, thinking of a paint scheme, I want it black and purple. no flames, everyone does flames , any ideas?
Old 11-03-2016, 12:06 PM
  #37
Team Lucas
painted and clear coting
Old 11-12-2016, 10:57 AM
  #38
Team Lucas
Painted and ready for hardware.
Old 11-12-2016, 02:21 PM
  #39
dwr9
dwr9's Avatar
Great looking boat. Doug
Old 11-12-2016, 02:51 PM
  #40
Team Lucas
thanks, I think it will look great once all the hardware gets installed and set off the silver. will post as I go. and I'm not Doug.
Old 11-13-2016, 12:38 PM
  #41
dwr9
dwr9's Avatar
I know. I'm Doug. Doug
Old 11-15-2016, 03:03 PM
  #42
Team Lucas
need some advice ... throttle arm going to bell crank. no matter where I put it it will interfere with motor collet tighting.
Old 11-16-2016, 12:21 PM
  #43
Ron Olson
Ron Olson's Avatar
A picture would help.to see what your issue is. Usually it's a header in the way.
The bellcrank should be an L when looking at it from the top. This isn't a great shot but how I do all of my gas boats.
Old 11-16-2016, 01:06 PM
  #44
Team Lucas
thanks for the pic, easy fix. I see a way to do it. best ron
Old 11-16-2016, 02:12 PM
  #45
Ron Olson
Ron Olson's Avatar
No problem. I try to keep everything as much as possible the same in all of my gas boats as it makes things a lot easier if I have to do an engine swap at a race. Once I find something that works for me I try to stay with it.
Old 12-02-2016, 10:44 AM
  #46
Team Lucas
Well it's finally getting finished today, bench start it tomarrow, and start breaking it in sunday. I'll try to post some pic,s today of finished boat.
Old 12-02-2016, 03:04 PM
  #47
Ron Olson
Ron Olson's Avatar
[Deleted]
Old 12-03-2016, 06:16 AM
  #48
Team Lucas
Finished! Will be taking her out tomarrow.
ID:	2192088   Click image for larger version
ID:	2192089   Click image for larger version
ID:	2192090   Click image for larger version
ID:	2192091   Click image for larger version
Old 12-04-2016, 01:24 PM
  #49
Team Lucas
Well it didn't die, sink, or blow up, and made it back to land with out hitting it. Brought it back home the same condition it left with. Always a good thing.
