Hand Held electric starter
I just bought a Pro Boat 48" RockStar RTR and the recoil starter is a plastic hunk of junk! The guy I bought it from also gave me one of those hand held electric starters and a few pulleys. I rigged it up to a motorcycle battery and promptly fried the wires! SO, I need some guidance on either 1) a better pull starter or 2) whats the proper way to set up the hand held electric start? There are no specs on the motor but I'm assuming the mc battery is a bit hot?
Thanks for any advice or help!
Dave
Dave
Sass78 (08-18-2020)
Hi,
I am like Dave and I also bought a Proboat Rockstar 48 inch gas boat and I had the same problems. I have been running it for the last two months and everytime it was really hard to start and the last time i broke the pull starter. I was looking at the electric pull starter but I couldn't find where to put the belt to start the engine ...I unscrewed the broken pull starter but I didn't see where I could put the belt.
But I look up the starters that Ron recommended and it looks like they don't work with belts ...am I right ?
I like the Rockstar but I think I will buy something else because it has a lot of problems, especially cooling problems (and I already did what the other users recommended like drilling a bigger hole in the rudder and enlarging the hole in the hull for better cooling but I already fried the carb gaskets etc...). I was looking at other RC gas boat brands on the internet and I found Dragon Hobby but it looks like that they do rc boats anymore.
If you could give me any advice for a future gas rc boat ...
Thanks a lot,
Sassan
Thanks a lot,
Sassan
You can get pulleys for either end of the engine. I tried one on the back replacing the pull-starter but it kept popping off slapping me hard on the wrist. You start trying to invent new swear words after a few times. There are some that also combine the flex cable collet with the pulley which might be a better way to go. https://zippkits.com/index.php?main_...roducts_id=225
