Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Throttle Linkages
Speed - RC Gas Boats Discuss gas RC boats right here!
Throttle Linkages
Old 03-14-2021, 08:00 PM
jase71
Default Throttle Linkages
What are the best options for throttle linkages with a zenoah and 1048 carb?
I can't post photo's yet but the best description of the mount is "Quick change style"
oz rc boat supplies has them under their hardware section.
Old 03-15-2021, 01:29 PM
Ron Olson
Ron Olson's Avatar
I didn't see anything on their site and half a world away I did have theirs saved. Try eBay for throttle linkage setups.
Mine are kind of like this:
https://www.ebay.com.au/itm/Accelera....c101195.m1851
Old 03-15-2021, 04:23 PM
jase71
Cheers, I'll have squiz around and see what I can find
Old 04-28-2021, 04:21 AM
ChrisK7
My Feedback: (14)
I've been using these direct cable drives. Been working great for me.
Direct Throttle Drive
Old 04-28-2021, 06:19 AM
Ron Olson
Ron Olson's Avatar
Joe and I were working on basically the same thing at the same time but I was using parts from Servo City. His turned out much better.
Here's more of a close-up of a normal throttle setup.
Old 04-28-2021, 11:39 PM
jase71
Cheers. Much appreciated. That's the way I've gone.
Old 04-30-2021, 05:30 AM
jase71
Quick question, why the spring on the end of the push rod?
Old 08-19-2021, 09:33 AM
Ron Olson
Ron Olson's Avatar
That's a Sullivan connector, the spring holds part of the cupped area held into the cup. Just pull it back and it unhooks from the ball, a fast way to do it. The usually ball and cup fittings work well also. I try different types of setups to see how well they work.
Old 08-19-2021, 01:10 PM
Hydro Junkie
Hydro Junkie's Avatar
The nice part about that connector is they can be used on just about any kind of carb. I have the same connector on the throttle arm of my scale hydroplane(the one pictured in my avatar) and it works great for quick removals and installations.
Old 10-25-2022, 02:53 AM
Del Cervelo
I have used gear cable from a cycle, cannot post pics yet but works a treat,
