Speed - RC Gas Boats Discuss gas RC boats right here!
Merco 35
Old 03-01-2004, 07:04 PM
Nerf Herder
Default Merco 35
Hi, I have an old merco 35 glow engine in a 1 metre balsa and ply racing hull using a 45x direct drive prop and flexible joint. I get plenty of water through the cooling head, the hoses I use are far bigger than the nipple on the engine, and the engine is fairly open to the air. the problem i have is the engine overheats and stalls after about 5 mins use[]. I am using straight fuel, no nitro with 20% oil and have the needle set so i get plenty of smoke from the exhaust and good throttle response. Any idea why this is happening anyone???
Old 03-01-2004, 08:35 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
Default RE: Merco 35
foaming fuel or an air leak
