Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Homelite Flywheel?
Speed - RC Gas Boats Discuss gas RC boats right here!
Homelite Flywheel?
Old 06-28-2004, 01:19 PM
blahh
Default Homelite Flywheel?
New to gas boats.
I have purchased a 25CC Homelite (from Home Depot) I am currently reworking it to be watercooled and removing un-necassary plastic etc.. I am looking at the flywheel to reduce weight. This motor currently has a front mount pull start which utilizes the flywheel. Any thoughts on how to remove weight from this? (I am thinking of at least removing the cooling fins and then rebalancing it) or would this even be a good idea?
Old 06-28-2004, 01:33 PM
Aaronie
Default RE: Homelite Flywheel?
You got it! That's what they usually do. [8D]
Old 06-28-2004, 03:56 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
only remove the fins if its been watercooled and if you do the fins, check the balance of the wheel before fin removal then return it to the same balance
Old 07-07-2004, 02:32 AM
markus1971
My Feedback: (28)
so how do you balance a flywheel? Does it require a special balancer?
Mark
Old 07-07-2004, 03:57 AM
pompebled
Look at www.shark-racing.com for homi mods.
Regards, Jan.
