Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
zenoah .red magneto how to test>???
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 10-13-2005, 03:16 PM
crazyotto
crazyotto's Avatar
Default zenoah .red magneto how to test>???
42cc zenoah seems like i have weak spark and sometimes no spark i tried a known good coil , didnt work so how do i test the red magneto near flywheel ???
Old 10-13-2005, 04:40 PM
Captain Ramius
Default RE: zenoah .red magneto how to test>???
Do you have or have acess to a (VOM) volt/ohm meter?
Old 10-13-2005, 08:12 PM
crazyotto
crazyotto's Avatar
yes i do , can you help me ??
Old 10-14-2005, 07:09 AM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
weak spark is a sign of a bad ground run a tag wire from the ground tag on the grey coil to the block and double check all connections. a shot of corrosion block when tightening the screws helps also
Old 10-14-2005, 08:02 AM
Captain Ramius
Red coil test
Coil 1160-71211 : infinity/185 ohms Coil core red wire/ coil core black wire
Coil 2629-71210 : infinity/255 ohms Coil core red wire/ coil core black wire
and check ground as mentioned above.
