Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
PLEASE HELP - WALBRO CARB FITTING?
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 02-10-2007, 10:45 AM
Shockwaver
Default PLEASE HELP - WALBRO CARB FITTING?
I WANT TO CHANGE THE POSITION OF THE INLET FITTING ON A WALBRO CARB? CAN YOU JUST TURN IT ??? FEELS LIKE SHES GOING TO BREAK - THANKS IN ADVANCE FOR INFO
Old 02-10-2007, 10:51 AM
Zac Price
Default RE: PLEASE HELP - WALBRO CARB FITTING?
Grab it at the base and give it a carefull twist. Try to get it where it needs to be the first time, as the more you move it, the greater chance for leakage.
Old 02-10-2007, 12:13 PM
TIA
TIA's Avatar
It's a press fit. Picture a tight fitting tube within a tube. I mean REALLY tight! Turn it too many times and it'll break. The ones that do happen to come lose usually develop air leaks and your motor runs lean all the time.
Set it and forget it!
Old 02-10-2007, 12:15 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
use a pair of pliers with sharp teeth and wide enuff to to span the fitting, dont pinch it too tight and give her a twist. if you do break it, you can take the brass insert out and thread in a fuel barb or JB weld a brass tube over it
Old 02-10-2007, 11:06 PM
Shockwaver
THANK YOU ZAC - LIFES - AND OLD - GOT HER TURNED OK NO DAMAGE - WENT ON MAIDEN VOYAGE TODAY - HAD A BLAST - 1ST GAS BOAT - 50" AEROMARINE PRO CAT - THANKS AGAIN ZAC
