Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
 Let's See You Do THIS with Fiberglass... >
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-08-2007, 12:15 AM
Default Let's See You Do THIS with Fiberglass...
This is our 46 inch Rivett round nose kit, built by Frank B.
Cowling is unpainted. He did an outstanding job on the deck!
Joe Petro
Old 04-08-2007, 01:55 AM
Quicksilver1's Avatar
Default RE: Let's See You Do THIS with Fiberglass...
Sick! can you post a bigger pic, I want to see the detail
Old 04-08-2007, 03:06 AM
thats real nice [8D]
Old 04-08-2007, 06:36 AM
Joe, Thats the new Zipkits hydro, right? Frank did indeed do a fantastic job! Looks like an expensive coffee table! SWEET! Brian
Old 04-08-2007, 09:13 AM
blizard05's Avatar
Joe, my teak is looking for a new home,can you say Rivett?
Old 04-08-2007, 09:45 AM
Yes details. I have always wondered how the epoxy is made to look so shiny and even.
Old 04-08-2007, 10:57 AM
Frank will have to tell us how he did it.
Joe Petro
ID:	659683   Click image for larger version
ID:	659684   Click image for larger version
Old 04-08-2007, 11:05 AM
that is just plain hot [8D]
Old 04-08-2007, 11:15 AM
Joe,
I wouldn't go so far as to say it couldn't be done with fibreglass. I do know that I certainly can't though! (can't do it with anything, rats!) THAT is very nice.
- 'Doc
Old 04-08-2007, 07:53 PM
dwr9's Avatar
After epoxy coating the hull I sand it til it's smooth and then give it a few coats of polyurethane varnish. I sand with 220 between coats and it will come out looking real nice if done carefully. Doug
Old 04-08-2007, 08:14 PM
Very nice work!!! Should be set-up with polished hardware engine ETC. and put on a fireplace as a show piece!
Old 04-08-2007, 08:52 PM
I agree. Waaaaay too pretty to get wet[:@]
I'm surprized about the 220 grit. I figured it would be much finer grit.
Old 04-08-2007, 11:02 PM
dwr9's Avatar
The hydro isn't mine, He may have gone much finer on that boat. I'm just mentioning how I do it. I have gone as fine as 400, but it doesn't look any better than 220, at least with the polyurethane varnish on wood. The polyurethane usually flows out nice and gives a nice glossy finish. I've never done automotive finishes on fiberglass, that is probably very different. Doug
Old 04-09-2007, 09:21 PM
Hi Guys, thanks for the good comments.
How I did it? I used minwax oil stain for the color tone, the dark shading was airbrushed with a darker color stain and spar varnish for the clear coat.
The Varnish was applied with foam brushes.
The varnish was sanded between between coats with 220 than 400 than 600 than 800 and final sanding was with 1500.
Then hand polished with a rubbing compound and final polishing with a carnauba paste wax.
If I had to do it again I would use water base stains then seal the stain and the wood grain with westsystems epoxy and then use the spar varnish, would have been alot less work, live and learn!
Frank B.
Old 04-09-2007, 09:39 PM
Beeutiful, Frank. Really, man. Make some furniture. That thing is just too sweet to be in the water
Old 04-11-2007, 12:32 PM
Thanks Paul M,
"make some furniture" lol.... rc boats are more fun!
Frank B.
Old 04-11-2007, 07:39 PM
Frank,
How are you coming along with "Miss Coffee Table"? [sm=bananahead.gif]
Joe Petro
Old 04-11-2007, 09:16 PM
Frank. I was thinking and ya know that boat not only looks better than my coffee table, I bet its ALOT faster too
If you do another one, how bout doing a thread so we can see how it's done
Old 04-11-2007, 10:34 PM
Hi Joe, my coffee cup keeps sliding off,
Paul M, the next one I do I will do that.
Frank B.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
