Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Velocity Stacks, do they really do anything?
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-08-2007, 05:47 PM
Drmeff
Drmeff's Avatar
Default Velocity Stacks, do they really do anything?
Do velocity stacks increase performance in any way or do they just look cool? I seem them in every nice looking modded boat, and since I am buying a new G260 stocker I am wondering if that would be a cheap way to add a touch more performance.
Old 04-08-2007, 05:48 PM
TERBObob
My Feedback: (21)
TERBObob's Avatar
Default RE: Velocity Stacks, do they really do anything?
Not on gas ... just nitro's
Old 04-08-2007, 06:21 PM
rickburnout666
rickburnout666's Avatar
velocity stacks / spit tubes whatever you want to call them work on gas/petrol motorcycles so i cant see why they wont/dont on the gas/petrol boat engines ????? smoother airflow increases power .
Old 04-08-2007, 06:27 PM
toyotatruckin
In the hull in building a V-stack wont even clear the cowl ,nd If you really think about it, no they dont do any more than the carb already does as there is a taper to the intake side of carb, polishing the carb intake side would do more than the stack as it would smooth the flow of air comming into it...Even that really wouldnt be worth the effort....
Old 04-08-2007, 11:08 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
most actually reduce intake air by as much as 10%, but the one pictured will increase air flow by as much as 8% over a stock carb opening
Old 04-09-2007, 05:57 AM
fastguy
Banned
my pocket bike goes faster with a stack but you cant see it but on a boat i just looks cooooool
Old 04-09-2007, 06:25 PM
Ed Sidders
Long Stack May help low end torque a little but not really on high end old&slow has a good suggestion for top end power at the rpm these motors are running but the stack will cut down on intake slobber inside the hull.
Old 04-09-2007, 06:43 PM
Justaddwata
Justaddwata's Avatar
I remember seeing a table that had test results for numerous intakes. Several had slight increases in performance while others had losses.
Based on that info I went without and cut my wins/losses.
Old 04-10-2007, 07:52 AM
the tuned intake length for a modded zenoah with an intake timing of 155deg is 3 13/16" that is measured from the piston face to the end of the spit tube. so you will ned to add just about 1/4" of spacer material under the spit tube base. problem is most boats run out of room for any kind of stack very quick, so your better off to do the best job you can at reprofiling the carb intake and give it a good polish. i had posted the complete intake list at one time the worst being a straight tube and the best being what i posted above
