1.7m CT 04 CAT Build 2XZens
#53
RE: 1.7m CT 04 CAT Build 2XZens
Made the radio box tray out a carbon sheet also made the foward bulk head and rear bulk head i layed the carbon up between two sheets of glass.
#56
the rams are from www.swissmodelpowerboatteam.ch the end links a friend over here got for me there not cheap around £9 each[X(] $72 for 4[X(] but extermly strong and no slop in the linkage i think ive seen them on tower hobbies site or there in the graupner catalog. if you cant source them and really desperate drop me a pm and ill get you some postage to the us should be all that much there very light.
thanks for the comment will kepp the thread updated as soon as i do more work
John
John
#57
ill let you know if i cant source them. gonn alook now. im lookign for ones with smooth operation and no slop. seems every set i try has some slop to them
#58
there will be no slop with these i have been using them for years and never have a problem with either slop or failures
tony
tony
#62
heres a few pics of the fuel tanks thanks for the fittings wayne also a couple of the rudder and drives. will see you all in a few weeks of to get married[:@] less boat building time now!
#63
Has this project made it to water?im fascinated! im looking to do something simliar and wondered where youget a counter rotation Zenoah? of is it a special home mod?
Cheers
Toby
Cheers
Toby
#64
FOR COUNTER ROTATION YOU JUST BUY THE ENGINE MOUNTS FROM SONIC RACING IN AUSTRALIA EVERYTHING THERE TO DO THE JOB
IT WOULD BE NICE TO SEE THE FINISHED PROJECT THOU. AND WHAT DID IT GO LIKE IF IT'S BEEN ON THE WATER??
GOT ONE TO PUT TOGETHER MYSELF BUT TO MANY PROJECTS AT THE MOMENT TO EVEN START IT .
#65
jsut a quick update , johnny poped round last weekend to pick up his radio for the hull , i know he has been very busy at a new job but plans to get back on to it very soon
the hull is 90% there , but has not been in the water
the rotation of the zenoahs is done by turnning the r/ h engine arround and driving offf the fly wheel , danny at sonic can do the mounts of you can make your own
i will talk to john soon and tell him to get his finger out , but as far as i know we will both hit the water very soon and will video it as well
tony
( hope you dont mind me posting for you john )
tony
#67
brillaint,thanks for the help.i have sent an email to sonic and will be ordering soon to build something similar!
Cant wait to get started!
#69
Looking nice Johnny. Have you managed to source a flex cable that is wrapped the "wrong" way for the reverse drive engine?
Glenn
Glenn
#70
JUST IN CASE YOU GUYS ARE LOOKING FOR COUNTER ROTATING SHAFTS ,,,HERE U GO
http://206.206.85.209/xtdoc/Details....R&store=mhzusa
#71
jonh look awwesome , one thing i dont see is shaft savers on your drive shafts if it were to loosen or break say bye bye to your prop shaft and prop . id consider doing this , im building the same boat and feel it is a must if you want to protect your investment .
#72
duce , i can help you out there as i have the same set up as johnny , the stub shafts have the savers built in to them so no problem with the lost props
tony
tony
#75
Thats a sweet boat Johnny, be happy if mine ends up being half as pretty. Keep up the good work, am using your pics for reference.
Cheers Mate
Stinky
Cheers Mate
Stinky
