Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
 What is ia butcher block >
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 10-11-2007, 06:58 PM
My Feedback: (26)
Default What is ia butcher block
Can someone explain what a butcher block is?
Old 10-11-2007, 07:02 PM
Default RE: What is ia butcher block
Big lump of wood that butchers put animals on to chop them to bits with cleavers, axes, hacksaws etc.
Gets lots of dings and gouges in it over time.
Why, have you got a boat that looks like one?
Glenn
Old 10-11-2007, 07:24 PM
Your kinda confused. It's called a "Butch Block". Origonally designed by Butch Fields. It is an aluminum block that is used to hold the stuffing tube where it goes thru the botom of the tunnel on Cats mostly. It is bolted in and eliminates the need for fiberglass work when installing the stuffing tube. They make them with different angles for installations in Hydro's and Riggers too. V hull guys are out of luck! LOL Brian
Old 10-11-2007, 07:33 PM
You probably don't want to use one for chopping up animals on then!!
Will make a mess in your boat.
Glenn
Old 10-11-2007, 07:35 PM
My Feedback: (26)
Very funny I guess I ment butch block. Is this so you can replace the stuffing tube easier?
thanks!
Old 10-11-2007, 08:16 PM
Noooo It's so you can install it easier. Whatever setup you use, you should have an 11/32" tube thru the hull for the stuffing tube to slide thru. That way replacing the stuffing tube is a snap. Brian
Old 10-11-2007, 10:00 PM
You can still chop turtles, alligators and water moccasins with a Butch block installed, but not reccommended.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
