!!!!!!!HELP 30cc Robie engine!!!!!!!
Hi there all
I have a 30cc robbie strimmer (weedwaker) engine off of my strimmer how would i go about connecting it 2 a prop shaft also what size hull dose a 30cc engine normaly go in because i have a couple of 32" hulls but it looks 2 big 2 go in there
. could i get hold of a 2nd hand sea queen (just abit bigger than a darter king) rip all the electric motors out and put my robbie engine in that as its 49" long and massivley wide or can anyone think where i can get a hull for a gas engine for £100 ($200) or less
Many thanks
Jonjoe
Many thanks
Jonjoe
You will need to find a hull around 43 or more inches in length and the ryobi with twin props will be pretty anemic at best, another thing the ryobi's coil used to have a rev limiter set at 9500 rpm but could be replaced by a standard Homelite coil.
Hi there
Thanks Ive alredy replaced the Coil did u say run twin props how do i link the motor 2 the shaft(s)
Many Thanks
Jonjoe
Many Thanks
Jonjoe
What about the fiberglass version of this: http://cgi.ebay.com.au/ws/eBayISAPI....MEWA:IT&ih=008
Thanks agian
Jonjoe
Thanks agian
Jonjoe
http://www.prestwich.ndirect.co.uk/deepvboats.htm
The Challenger at 95 quid might do for you Jonjoe.
Glenn
Glenn
