Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
MaxCatV1-L Scratch Build
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 08-31-2010, 04:08 AM
  #651
MaxCorvette
MaxCorvette's Avatar
Default RE: MaxCatV1-L Scratch Build
No they are still in business, but their provider is down. Seems to be a big issue.
Old 09-01-2010, 11:19 AM
  #652
ThomasSalin
Some progress, canopy from RBCkits
Thomas
ID:	1493678   Click image for larger version
Old 09-15-2010, 04:04 AM
  #653
we2psd2phn
just a few more photos still have heaps of work to go but getting there
ID:	1501129   Click image for larger version
ID:	1501130   Click image for larger version
ID:	1501131   Click image for larger version
ID:	1501132   Click image for larger version
Old 11-14-2010, 12:14 AM
  #654
METALGEAR1
Ok thats it... you guys just did it. Im going to print this plans and get me some wood. The only thing is that here in South Africa I can get 4mm marine ply and thats it nothing thinner. So the whole thing will be of 4mm ply, the ribs the sheeting the sponsons every thing, hope it dosnt weigh to much as the stock zen will have to do as here is no hopups availeble.
Old 11-14-2010, 04:14 AM
  #655
MaxCorvette
If it really is 4mm marine grade ply then look for cheaper softer ply that is not marine grade.
This because marine grade ply is very heavy, good for the ribs and stringer but much to heavy for hull sheeting.
Hull sheeting 3mm normal ply or 2mm marine grade ply, else it will be to heavy for stock zenoah.
Marcel
Old 11-14-2010, 12:59 PM
  #656
METALGEAR1
Thanks Marcel.
I bought the marine ply this morning, printed a sticker and began the cutting. The stringers and almost all the ribs is done. By normal ply do you mean pinewood ply? I was wondering about balsa wood for the covering as these are easy to come by. Then maybe glass it inside and out.  One more thing..the running hardware will the Black Jack 55 stuff work as this is freely avalible I think I will import a prop from someone just dont know wich one and hope it doesnt get stolen again in the mail.
Old 11-14-2010, 01:36 PM
  #657
MaxCorvette
Yes, pine or poplar ply, I use poplar. here they also have balsa ply, that is birch out and balsa in.
All balsa would not be my choice since it is soft and doen't take hits very well, Glass in and out has to be done anyway whatever wood you choose.
Blackjack hardware I don't know, my first choice is Speedmaster.
As for a prop, get a Propshop 7016/2 and your set to go.
Marcel
Old 11-15-2010, 02:24 PM
  #658
METALGEAR1
Thanks I think Ill go with the normal pine ply 3mm. I see your from the Nethers.. its much like Afrikaans so ek dink jy sal dit dalk verstaan dit is my moeder taal. Thanks for the advice maybe Ill import all the right stuff and weight 3 months or so for it, I do know a Importer that garantees a 7 day delivery but its like 35 us $ extra , maybe worth it. At the same time maybe get a decent motor like a Bonzi Zen or a Quiqe draw or some thing.
Old 11-15-2010, 02:31 PM
  #659
METALGEAR1
Sorry just went to the net and searched for that prop :
The prop shop is Dia: 2,76 x 4,41 and the pro boat is: dia: 2,74 x 4,2 dont kno ..... help please!Specifications
DIA:2.76
PITCH:4.41
BORE:.250" (1/4")
Old 11-17-2010, 11:29 AM
  #660
METALGEAR1
I found some airplane ply of 2mm think itll work for the covering?
Old 11-17-2010, 11:37 AM
  #661
MaxCorvette
Yes, will be great! Not sure about the props, just don't know them
Old 11-21-2010, 05:20 AM
  #662
METALGEAR1
So here is were I at the moment. Please do comment good or bad. I do know the one spar reinforcement is broken just at the joint will rectify it asap.
Old 11-21-2010, 07:35 AM
  #663
MaxCorvette
You need to build on a jig else the nose and sponsoons will not be straight...
It needs to be true and straight any diiference left or right will cost speed or worse make it run cirkels
Marcel
Old 11-21-2010, 09:43 AM
  #664
METALGEAR1
I have a jig But took it out to get the photos the jig is as solid as they come I mesured it across for sraightness its perfect and its sqeure and true. Now its only a lot of sanding to get all tollerances to as small as posible and get the epoxi running marks out.
Old 11-25-2010, 01:52 PM
  #665
METALGEAR1
Got the motor today, stock 26 Zenoah. There is a guy in cape town some 1700km from here that has done some mods on them with greate success will send it there next week. As far as the build goes, I ordered some 2mm spruce ply and is still wiating for it (Africa time). Will start covering as soon as it arives. Glued the supports in all the right places an ordered the glassfiber too. I will be useing 4 oz glass in and out. Dont know if it makes a differance but its woven and not mat.
I will see in the end.
Old 11-25-2010, 04:14 PM
  #666
martno1fan
martno1fan's Avatar
My advice just glass the inside seams no need to glass outside,that will just make for a heavy boat .
Old 12-09-2010, 08:04 AM
  #667
METALGEAR1
Still waiting for the ply so I cancelled it..... Now a quistion to the pros can I cover the hole thing in 2,5mm balsa and glass it in and out. I think it will hold , Im not a racer just want a nice fastish boat.
It is bad to live in a under developed sloppish kind of service country. Not to say my country bad but service delivvery is not up to par with the rest of the world. Im just trying to put things to use that is availeble.Help please!!
Old 01-28-2011, 12:39 AM
  #668
we2psd2phn
just got my 2 power trim 2007 just waiting to order my 2 twin rcmk the power tim look **** hot
Old 01-29-2011, 03:23 AM
  #669
we2psd2phn
hey does anyone know what the length of the hpr 233 ruder is
Old 06-10-2011, 05:44 AM
  #670
martinchoj33
All that weighs the ship that you do in fiber?
Old 12-07-2015, 02:17 PM
  #671
KD0EM
I'm Back! Hello to every one on the Speed - RC Gas Boats Forum.
A lot has happened in the last few years, I don't think I will be adding anything more to this build thread, However I may be starting a new RC gas deep V build this winter.
Anyway I misted this forum very much!
Harold
