Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
MaxCatV1-L Scratch Build
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 06-10-2008, 08:29 AM
  #76
MaxCorvette
MaxCorvette's Avatar
Default RE: MaxCatV1-L Scratch Build
Hi Mart, the cat is 16"1/4 as it is, so that is not widening it Would make it 17" then.
On very rough water it does tend to barrelroll in the corners if it catches a wave, not sure it widening will prevent it.
This is one of the reasons the V2 has a lower cg.
But then again a cat is not for rough water, use a mono then
Marcel
Old 06-10-2008, 11:13 AM
  #77
martno1fan
martno1fan's Avatar
Sorry Marcell i was told it came out at 13 1/2" good to know its 16" it should be fine,i think your improvements will help especially the tunnel shape change heres a pic of a cat i found is this the kind of thing you had in mind?.
Old 06-10-2008, 12:16 PM
  #78
MaxCorvette
Woow, cool tunnel design!
Well something like that, but no strakes, remind you it is a wooden build, so not to many special attributes.
Here is a few pics of the V2-S tunnel, the large version will be almost the same [bigger ]
As you can see the mid section of the rear is closed now.
ID:	968006   Click image for larger version
Old 06-10-2008, 12:33 PM
  #79
martno1fan
martno1fan's Avatar
Yes this cat i found on this site it was designed and built by someone from the site but he seems to have dissapeered as i tried to contact him a while back about one of these as i really like it.Yours is nice too,nothing wrong with wooden boats i now have two.My first was a scratch built mono from plans and the second i cheated and got a kit .Hres a pic of the kit and a cpl more of that cat for you,unfortunateley i doubt the yng lady comes with the hulls .
ID:	968010   Click image for larger version
ID:	968011   Click image for larger version
Old 06-10-2008, 12:56 PM
  #80
thevirginian
martno1fan;
That's exactly what I am going to do: Stretch the width a tad. I already altered the plans a little bid to give it smoother curves. I think this cat is absolutely a must to build. I hardly can't wait to get started. Need to build me a retrieval boat first. And finish my Hydro. She is about ready for her first coat of paint.
Old 06-10-2008, 05:23 PM
  #81
KD0EM
Hello every one, Thank you all for your comments and input on this cat build. Not too much done today, I just popped off the building board, I had it CA to the board, I had one part of the tunnel sheeting that did not stick had to repair it. Here are a few more pictures.
Harold
ID:	968184   Click image for larger version
ID:	968185   Click image for larger version
Old 06-10-2008, 06:33 PM
  #82
KD0EM
ORIGINAL: MaxCorvette
That would be great trying to squeeze a 35cc in this hull
I hardly could get a PUM260 to fit [more a height issue].
This hull has an overhang on the rear, but the sponson length is hardly longer then a PPB skater.
It's even narrower then most cats out there.
Maybe if I have saved enough I'll build a 1,6-1,8 meter twin in the future
Marcel
Hi Marcel
I know I am getting ahead of the build. I have got this PUM 260 Zen mild mod with a clutch that I would like to keep on it! Do you think I can get it to work? As far as I can tell the shaft will go thou the tunnel near or at rib #6.
Harold
ID:	968242   Click image for larger version
ID:	968243   Click image for larger version
ID:	968244   Click image for larger version
ID:	968245   Click image for larger version
Old 06-10-2008, 08:01 PM
  #83
thevirginian
Hey Mart;
That cat in the far right picture got some breathtaking curves, doesn't she?
Old 06-10-2008, 08:35 PM
  #84
dwr9
dwr9's Avatar
great sponsons on that cat Mart. Doug
Old 06-10-2008, 08:59 PM
  #85
build4less
What cat?
Old 06-11-2008, 01:49 AM
  #86
MaxCorvette
Hi Harold,
A zenoah will do fine in this hull, as for the clutch....Why run a cat with a clutch? It's heavy and you need a waterpump also.
Also cats have hardly any control when they go slow...I would not mount it.
Also it will give you height issues.
My motor is mounted at a 10 degree angle and very close to the bottom, else the canopy has to be so high.
With a clutch this will be even worse.
Here are some pics I just made of the inside....incl. some repaired damage on the lid mount in the front.
ID:	968495   Click image for larger version
ID:	968496   Click image for larger version
Old 06-11-2008, 05:42 AM
  #87
dannyual777
MaxCorvette, what is the CG of your cat and with your experience with it, how much would you change it on your next build? I've got my plans printed out and I'll start the build later in the summer.
Danny
Old 06-11-2008, 06:31 AM
  #88
MaxCorvette
CG is at 31% and I will not change this on the next build.
Strut is usually set level, so no extra lift or downforce. I like a steady cat that is not to flighty.
The cat can run full throtle with winds to 5 beaufort as long as the waves are short and low, it doesn't like big waves.
Old 06-11-2008, 06:49 AM
  #89
thevirginian
ORIGINAL: build4less
What cat?
The one holding the cat[sm=tongue_smile.gif]
Old 06-11-2008, 06:55 AM
  #90
dannyual777
Thank you, Max. I'll build mine to the same spec.
Old 06-14-2008, 09:55 AM
  #91
KD0EM
Hello all, I started cutting and putting the sides of the hull on now. As you can see in the pictures I put some X braces on the inside of the ribs and stringers to hold things in alignment, got one side epoxy on, Waiting for it to cure so I can see how I came out. Hopefully OK or the build is trash at this point.
Harold
ID:	970269   Click image for larger version
ID:	970270   Click image for larger version
ID:	970271   Click image for larger version
ID:	970272   Click image for larger version
Old 06-14-2008, 11:38 AM
  #92
MaxCorvette
Don't think anything can go wrong the way you build
The extra X-braces should not be needed, but won't hurt either.
And with the amount of clamps you use, it can't be possible a piece is still open
Only thing that can go wrong is if the epoxy was mixed wrong, so I'm not scared it will fail this parts of the build.
I Like the way you build.
Marcel
Old 06-14-2008, 12:00 PM
  #93
Dreamin Hemi
Dreamin Hemi's Avatar
Hey Harold, you woulden't happen to have a clamp or two I could borrow.... do ya?
Old 06-14-2008, 12:13 PM
  #94
KD0EM
Hey Dreamin Hemi good one, your the man.
Old 06-14-2008, 12:21 PM
  #95
KD0EM
Hi Marcel thank you vary much for your confidence in my building ability. The thing that I am wondering about is the resin that I used; it was grate plains finishing resin, not sure if it will hold good enough.
Harold
Old 06-14-2008, 12:41 PM
  #96
MaxCorvette
Would have been better if mixed with glassbubbles or something like that, but there shouldn't be to much tension on this part.
Will probably hold long enough to make some thickened epoxy and use that to make fillets at the bottom and top support stringer this will only make it stronger and easier to glass.
I glued my whole cat with water resistant wood glue and afterwards I fnished it with thickened epoxie along all the ribs.
This never gave me any problems.
Old 06-14-2008, 06:12 PM
  #97
Dreamin Hemi
ORIGINAL: KD0EM
Every once in a while one comes to mind
Your build is looking great, being a shop teacher I can respect the time your're taking with your laminating and clamp use . Keep it up!
-Scott
Old 06-15-2008, 08:39 AM
  #98
KD0EM
Hello,
Well the side sheeting is done and sanded to shape some what, the finishing resin that I used finally did cure, it just took longer then I thought it would. I guess the next part of he build will be fiber glassing the in side of the hull, I am not sure what oz glass to use! Marcel maybe you can help me on what oz to use inside the hull?
Thank you, all for the comments.
Harold
ID:	970814   Click image for larger version
ID:	970815   Click image for larger version
ID:	970816   Click image for larger version
ID:	970817   Click image for larger version
Old 06-15-2008, 11:19 AM
  #99
MaxCorvette
Looks good Harold!
See you made the tunnel sheeting a bit longer, that is very good. I forgot to tell you that I sanded a piece of ply to the correct angle to make it straight [vertical] so you can mount the hardware.
This will make a very thick transom. I even put M4 inserts in the wood to mount the hardware.
The V2 has a straight transom, easier to build.
Not sure about the grams to ounces conversion, but according to an online calculator I used 2.82oz glass [80gr] on the inside and an extra layer on the tunnel of 5.64oz twill? glass [160gr].
On the outside I put 1.76oz glass [50gr].
Hope these values make sense.
Marcel
Old 06-15-2008, 05:47 PM
  #100
fuelman8
fuelman8's Avatar
See I told you it would come out just fine!! Looks great.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
