Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
I Got Wood Easy Vee
Speed - RC Gas Boats Discuss gas RC boats right here!
I Got Wood Easy Vee
Old 08-25-2008, 08:17 AM
i8tweety
i8tweety's Avatar
Default RE: I Got Wood Easy Vee
One was racing in London, Ontario this weekend. It proved to be fast, stable, and durable. Definitely a nice boat.
Old 08-25-2008, 05:30 PM
doomracing
i mite have to get one for something to do over winter.
Old 08-25-2008, 07:19 PM
JakeDW
I havent had a chance to work on it the last few nights but its allmost ready for the bottom sheets.
Jake
Old 08-26-2008, 08:30 PM
JakeDW
One bottom sheet on[img][/img]
Jake
Old 08-26-2008, 09:27 PM
doomracing
how thick is the sheeting? i'm sure you will be putting fiberglass matte over it right? looking good though. not much longer till the hull is fully built. your a inspiration to me
ok... i take it your using epoxy to assemble it, but wouldn't ca be better then epoxying everything together before putting on the deck? that's how i built my 1/10 cracker box.
Old 08-26-2008, 09:47 PM
  #31
JakeDW
The frame was built using CA and then epoxyed but side sheets and bottom were just epoxyed on only.This is a kit so all wood came with it I will check the thickness.Lots of these have been built on here if you use the search you can pull them up.
Thanks Jake
Old 08-26-2008, 10:01 PM
  #32
doomracing
i know it's a kit, but was just curious how thick the sheeting is. waiting for the epoxy to set would kill me. i'd just ca it then epoxy everything ounce the hull was done, but before the deck went on. just my 2 cents worth is all. i mite get one for a winter build.
Old 08-26-2008, 10:18 PM
  #33
JakeDW
I hear you on doing it fast I am allso that way but with the other 2 hulls I have going its great to do it a bit at a time.This was going to be my winter project allso but when it came I just had to start building it.
Jake
Old 08-26-2008, 10:21 PM
  #34
doomracing
LOL i here ya bro
Old 08-26-2008, 10:53 PM
  #35
dicko
dicko's Avatar
ORIGINAL: doomracing
CA is used to tack the sheets in place, epoxy adds the strength as it has some flex in it which CA does not. No glass sheet is needed on these boats if they are built properly. The epoxy in the wood has enough strength to hold it together. Some glass tape along the seems is all that is needed. All you'll do by glassing the whole hull is add unnecessary weight. The wood sheeting is usually 2.5 - 3mm 3 ply or 1/8th 3 ply.
Here's a thread of a boat I built from full scale plans that I scaled down to a 1/4 scale boat.
http://www.rcuniverse.com/forum/m_64...tm.htm#6406405
Old 08-31-2008, 10:46 PM
  #36
archer7153
Laoniu, where can you buy a motor for $50 ?
Old 08-31-2008, 10:51 PM
  #37
dicko
dicko's Avatar
ORIGINAL: archer7153
He lives in China, what we pay 200 for he gets for next to nothing. No import tax, no shipping etc.
Old 09-03-2008, 08:56 PM
  #38
JakeDW
Both bottom sheets on and palined down(blue tape is holding the bottom togeather with some extra epoxy)Slow but sure
[img][/img]
Jake
ID:	1025721   Click image for larger version
Old 09-03-2008, 09:50 PM
  #39
doomracing
ORIGINAL: dicko
isn't that what i said basicaly?
Old 09-03-2008, 10:00 PM
  #40
doomracing
does the kit say where to mount the engine, or at least the balance point? do you remove the last former? i do think i'll be getting one of these for winter. i want a zen for my rio, and it's fuji will go in this.
great build so far. i take it the deck is flat?
Old 09-03-2008, 10:09 PM
  #41
JakeDW
If you look at the right side stringer(motor mount) it has a cut out for the carb Joe has said to mount the motor with in that cut out.The deck is flat with a slight downward curve to the nose.The only part removed is the middle of the first former it is only held in a a few points.It is a really easy build .
Jake
Old 09-03-2008, 10:38 PM
  #42
doomracing
cool. i didn't see the cut out. yup i do think i gotta get one.
Old 10-24-2008, 06:08 PM
  #43
clegen3
Don't know if im posting this in the right place, and i don't want to highjack the thread, but does anyone know how much i should sell me easy vee for? It is fully complete, painted, engine(enforcer/zenoah 23cc) is installed, so is the prop(prather 275) and hardware(xp-2 inline), basic radio system connected... the motor has two runs on it, and its pretty fast(~35-40). I took my time on the build, and its pretty nice, the deck is filled with noodles. it would be a RTR sale. about how much could my easy vee sell for???
Corey
Old 10-24-2008, 06:16 PM
  #44
JakeDW
Hey you brought my thread back up I have not done antthing else to this hull since the pic i need to finish it up.
Jake
Old 10-25-2008, 01:59 PM
  #45
rcboateric
Banned
What do you think of this ATR fleabay 51" mono, homelite weedeader engine with a clutch, I'm interested in it since I'm planning to go back to a small pond which is closer to my home, it is the best slow boat for that pond. you might PM me if you still want to sell yours.
http://cgi.ebay.com/Gas-powered-Radi...1%7C240%3A1318
