Speed - RC Gas Boats Discuss gas RC boats right here!
zen octane?
Old 08-22-2008, 09:57 AM
firelite_marine
firelite_marine's Avatar
Default zen octane?
Is it safe for the engine to use 110 octane in a stock zen?
Old 08-22-2008, 09:59 AM
Hover259
Default RE: zen octane?
We use only regular pump gas.
Old 08-22-2008, 05:28 PM
OLD_SLOW and in the WAY
OLD_SLOW and in the WAY's Avatar
higher octane gas burns way too slow for these realatively low compression engines... meaning that the fuel charge is still burning going out the header and not being used in the power stroke.
regular gas 87octane is preferred by the mfg but 55 octane camp fuel runs cleaner and cooler
Old 08-22-2008, 05:42 PM
Justaddwata
Justaddwata's Avatar
ORIGINAL: firelite_marine
110 - your going the wrong way For these motors lower is better. 87 is a good starting point but you can reach for camp fuel like Larry said too.
Only thing you will get for your 110 is an empty wallet and a very hot (temp not performance) motor. It would probably run worse than if running 87 to hazard a guess.
Old 08-22-2008, 08:48 PM
Canadian LoCo
Canadian LoCo's Avatar
you guys are right the lower octane in the 2 stroke the better
the higher the octane in a 4 stroke the better that my 2 cents
the higher the octane the slower it burns =more heat
Old 08-23-2008, 07:42 PM
lineman1221
how do you use camp fuel? i like the whole lower octane=lower temp idea. im very interested in useing this kind of fuel and any input will be a great help. thanks guys
Raymond
Old 08-23-2008, 10:10 PM
Justaddwata
ORIGINAL: lineman1221
Raymond
Mix oil with camp fuel (usual oil in same mix ratio), pour into tank, Run. No needle changes. No problems
Old 08-24-2008, 07:55 PM
lineman1221
sweet, thanks, i'll give it a shot[8D]
Raymond
Old 08-24-2008, 08:08 PM
black talon
black talon's Avatar
when you run camp fuel and pump gas 50/50should you increase your oil content more than 6oz per gal.?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
