Sprint Cat revamp
RE: Sprint Cat revamp
Here is more pics all holes filled and yes I did what I said I was not going to do use filler it had some filler in it anyway so what the hea it is light weight filler not bondo I would normaly use Rage Gold but was out this is the micro spheres stuff .Any glass or filler on this hull has been sanded way down and will get sanded some more .I will weigh the bare hull when I am done so you guys know what it weighs.[img][/img]
Jake
Jake
Cowl came in today looks like a 1 1/2 in cut out of the middle to fit up.I should be able to get to it in the next couple of days.[img][/img]
Jake
Jake
#33
Thanks Eric ,should have the hull in primer tomarrow.
Changes
Capped the hull and deck togeather.
Smoothed and altered the tunnel transition in the front/I will put up a pic of it later
Altered a f41 drag cowl to fit the Sprint cat.
I have a great theam for it since it is drab green and will run an SS motor but not sure how many people would get offended my wife looked at me and .
Eric you will be pleased to know this on will get a short stand off and tapered rudder and a standard short strut TSB of corse.
Jake
Changes
Jake
#34
Banned
ORIGINAL: JakeDW
Changes
Jake
Changes
Jake
#36
Banned
ORIGINAL: JakeDW
I run 10 oz per gallon Honda HP2 and the recomended settings are 1 high and 2 1/4 low .
Jake
Jake
#37
Tunnel entry, the huge hangover has been sanded to match the bottom and the angle that ended at the shoe box cap has been changed will it help not sure but it sure looks nicer.[img][/img]
Jake
Jake
#38
Banned
I found that this sprint cat needs a CG that is more than 32% of the setup, otherwise it will run unstable in the high speed, added total about 18 oz of weights to mines, now her nose is heavy enough to keep it down, as the results, she runs like glue in the water when she gets up to low to mid 70's, I more love this cat since I got her out from 60's.
#39
I set my Flacons CG at 35% and the Sprint Cat will be the same.Here are some pics of the sprint cat in primer needs some more love on the sides to get arched line stright and needs more sanding and some glase puddy.[img][/img]
Jake
Jake
