Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
MHZ GTX BUILD
Speed - RC Gas Boats Discuss gas RC boats right here!
MHZ GTX BUILD
Old 10-01-2008, 11:01 PM
Gpap
Default MHZ GTX BUILD
Hi Guys
I thought I would share my GTX build with you all. We are building this for our display and have a bit of Fun
The Boat MHZ GTX
Engines 2 x SLAM260
Drives 2 x WD200 Steerable Drive
Clutch/Gear Box TBA
we will need to cut and offset the transom in order to take the two drives as they need to be 90 degrees to the buttom of Hull.
GP
Hobby Depot P/L
ID:	1044682   Click image for larger version
ID:	1044683   Click image for larger version
ID:	1044684   Click image for larger version
Old 10-02-2008, 12:38 AM
Justaddwata
Justaddwata's Avatar
Default RE: MHZ GTX BUILD
Looks a nice build you have going on there GP.
Planning on Counter roating the props?
Keep us posted.
Old 10-02-2008, 05:27 AM
Gpap
Hi Guys yes we will be counter roating props, I have given it a thought and I think it will ride and handle much better.
Well its been a long day for me trying to run the shop and build the GTX in between but I have had a good run late this afternoon.
I also received all my anodissing peices today and from the pictures below you will notice that I Have strip down the drives and had them done in Gold, I will also run Gold with my water jackets, manifolds and possibly the pipes.
thanks for looking and if anybody has any ideas let me know.
GP
Hobby Depot P/L
ID:	1044732   Click image for larger version
ID:	1044733   Click image for larger version
ID:	1044734   Click image for larger version
ID:	1044735   Click image for larger version
ID:	1044736   Click image for larger version
Old 11-13-2008, 04:11 PM
Gpap
Hi all have spent some more time on the boat, I have found some small design faults and I will be rectifying that this week. The fault is on the steerable drives,,,,,, once mounted the adjustment of the drive angle is hard to adjust dew to the fixed mounting plate so I have pulled them apart and will be re making them so the angle of the drive can be adjusted with two small spanners with out pulling them out.
I also have my engines just about ready, I have reversed one of the cylinders so I can have the carbs on the inside witch will also allow the pipes to go down each side, the clutch/output drives are also from WD200 but are manufactured by somebody else (thomas marxs) also German they allow for two counter rotating outputs or you can chose one counter rotating and one standard on each side they are 1 to 1 gear ratio and the best part about these drives is that they do not require any special pull start or mounts etc and will balance the final drive much better than having engines reversed.
ID:	1071491   Click image for larger version
ID:	1071492   Click image for larger version
Old 11-15-2008, 12:07 AM
Justaddwata
Looking good.
Loving those gearboxes. Keep the pics coming !!
Old 11-26-2008, 03:33 PM
Gpap
Hi Guys
I have managed a few spare hours so I put them into the build.
ID:	1079443   Click image for larger version
ID:	1079444   Click image for larger version
ID:	1079445   Click image for larger version
ID:	1079446   Click image for larger version
Old 11-26-2008, 04:47 PM
sheograth
Moderator
sheograth's Avatar
It's so pretty [&:]
Old 11-26-2008, 09:10 PM
JCAustralia
George
Looking great and taking shape
I hope to see it real in your shop one day.....
JC
Old 11-26-2008, 11:47 PM
coyv10
Where did you get the 90 deg in take manifolds for the carbs?
Old 11-27-2008, 12:05 AM
Justaddwata
Amazing how much work has gone into having those motors side by side - I take my hat off to you there - I would have had to offset one or the other and gone the easy route.
Keep it coming there George
Old 11-27-2008, 01:23 AM
Gpap
we stock them, they are about US$52.00 each
Old 11-27-2008, 01:27 AM
Gpap
thanks Guys
yeah its taking some time but its hard to jugle the shop and our other buisness and try and find time to do our own boats,, customers boats come first and then our own.
Im going out with some of the guys on sunday to do our first test run, and hopefully we get some action pics and vids to share with you all.
once we are happy with it we will go to paint
Old 11-27-2008, 11:27 AM
ByronRC
ByronRC's Avatar
ORIGINAL: Gpap
Who is we? so I know for future reference.
Old 11-27-2008, 03:35 PM
Dana W
Nice job , can't wait to see the test results . Gota love that drive .
Old 11-27-2008, 03:48 PM
Dana W
George , I have to wonder how come the transom wasn't already set at 90 degrees from the bottom of the hull when it was made originally ? I guess I figured all R/C boat hardware was designed knowing the transom was 90 degree's from the bottom .
Old 11-27-2008, 05:06 PM
martno1fan
martno1fan's Avatar
Not all transoms are at 90% mine def isnt on my own stepped vee design so far its never been a problem setting one up but then i dont use stingers or outdrives on mine,even if i did a small offset can be made using some hardwood cut to shape .The fountain hull is another example its transom is also not at 90%.
Mart
Old 11-27-2008, 05:32 PM
Gpap
ORIGINAL: martno1fan
Mart
Ok this Hull is a true scale Model of the Original Outerlimits GTX XXX (47 foot) Hull, www.outerlimitspowerboats.com
My suppliers have now released a new set of drives that have the 15 degree angle on them but I have yet to see what they are like, I went with these drives for many reasons and the biggest reason was scale,, I can not advise on performance until this sunday.
Old 11-27-2008, 05:53 PM
martno1fan
martno1fan's Avatar
Scale boats are special as far as im concerned and when you build a boat this big its the only way to go in my opinion.The drives you describe with the angle built in is a good idea,ive made offsets from wood and aluminium before if need be too.Thats what makes things more interesting for me the challenge of making things work .I cant wait to see how your boat runs,its something i can only dream about at this moment in time but one day its something im deffinateley going to do is build a big boat and yes it will be as scale as possible.Good luck with her maiden,look forward to seeing how she performs.
Mart
Old 11-27-2008, 06:55 PM
wetsleeves
ORIGINAL: ByronRC
ORIGINAL: Gpap
http://www.hobbydepot.com.au
[sm=teeth_smile.gif]Peter
Old 11-27-2008, 10:11 PM
nvs motorsports
If your a shop arent you supose to comply to forum rules an state so
I had to change my details cause i manufacture hulls
Just a friendly warning love ya work by the way
Old 11-28-2008, 03:45 AM
Gpap
ORIGINAL: nvs motorsports
Thanks Bud
Have changed to suit,,, I did not know it was a crime sorry Guys.
Old 11-28-2008, 04:02 AM
nvs motorsports
Yes crime punishable by by selling all your boats an spending it on your wife
I think we can all vouch to sell our wifes an get another boat hahaha
Old 11-28-2008, 04:29 AM
Gpap
To true but I would not swap her for anything,,,, she is the one who advises that I need keep building Shop demos,,,,,,,,, just buy them a thing or two and they will leave you alone.
Old 11-30-2008, 09:03 PM
glennb2006
Mart
Mart,
you mention your own stepped vee design in the above posting, is it not the case that on the hull you make reference to, that you, in fact, copied it from someone you bought it off?
I know you made the freeboard higher etc, but, still a copy and I don't think you can claim it as your design.
Regards,
Glenn
Old 12-01-2008, 04:32 AM
martno1fan
martno1fan's Avatar
ORIGINAL: glennb2006
Mart
Mart,
Regards,
Glenn
WRONG i did not copy this design i took my old discontinued hull cut it up changed the design considerably and made my own design from the parts,i changed the step,the free board,the width and length not to mention it has a new top and now has a canopy which the old one did not.For your information i did not higher the freeboard i lowered it 2" at the highest point,so yes i do consider this my design whatever you may think not that i care what you think.There are many large hull manufacturesrs out there doing far worse than me by blatantly copying others boats 100% and it wouldnt suprise me if you owned one at some point?,i know there are quite a few apache copys out there aka the makara (just an apache copy ) .
Mart
ps if you wish to contiunue this discussion Glenn feel free to pm me or call me on the phone theres plenty more id like to say but forum rules wont permit me.
