Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Update on my build
Speed - RC Gas Boats Discuss gas RC boats right here!
Update on my build
Old 12-02-2008, 05:59 PM
BarnacleNZ
Default Update on my build
The last few days i have been working a bit on my boat.
Hers a few pics of my progress.
Old 12-02-2008, 06:23 PM
dadkins
Default RE: Update on my build
WOW - it looks like the back of that boat was shot by a shotgun.
Old 12-02-2008, 06:30 PM
BarnacleNZ
it missunderstood 'say cheese' for "swiss cheese" i should have been a comedian...
Old 12-03-2008, 02:47 AM
BarnacleNZ
i just glassed the stringers in, all went well. Just curious, is 1 layer of fiberglass sufficient?
Old 12-03-2008, 03:18 AM
MrMikeG
That header is too long for a band pipe, you might want to see if you can trade it before using it.
Old 12-03-2008, 03:21 AM
wayneuk01
a 105 degree header looks to me like it may fit
Old 12-03-2008, 03:25 AM
BarnacleNZ
how will this pipe affect it?
Old 12-03-2008, 04:35 AM
martno1fan
martno1fan's Avatar
You wont be able to tune the pipe to its peak ,you either need a cone to cone pipe or as said change the header , as Wayne said maybe a 105% that should bring it out dead centre at the transom.As regards your stringers what cloth or mat did you use? 1 layer should be enough just depends what you used i supose,but looking at your stringer setup id say it will be fine as theyre locked into the transom support and you have a brace forward too so you allready have a pretty strong framework .
Mart
Old 12-03-2008, 04:41 AM
BarnacleNZ
I'll just stick with this pipe for the time being i think. I used 50mm fiberglass tape, the woven type.
Old 12-03-2008, 04:51 AM
BarnacleNZ
I bought the cheapest radio box i could find the other day, its an Arrowshark model, its not all that bad, i held it 3ft underwater for a few mins in the pool and its was still bone dry inside but i suppose it doesnt have any linkages coming out of it at the moment.
Old 12-03-2008, 05:03 AM
martno1fan
martno1fan's Avatar
I use tape on my rails you should be fine,did you do both sides ,as regards ther radio box they can flex a bit so a good idea is to use some plywood in the base to fix your servos to so the box doesnt flex etc.Not familiar with that box it might allready have plywood insert?.Personally i make my own wooden radio boxes as i find them stronger,but lots use your type so you should be fine.With that pipe on that header you wont get the motor to rev out as it will be too long and you wont be happy with the performance,i think as said you should either send it back and ask to swap for a 105% header or sell it and buy one just my opinion.1" or more too long and you will notice a massive difference than having the pipe set at the correct length,on my hydro i had the pipe set too long by 1 1/2" due to a mixup and speed was way down maybe 40 mph but once i put it right it was like night and day and i picked up like 15-20 mph so it does make a big differnece.
Mart
Old 12-03-2008, 05:08 PM
MrMikeG
Once your pipe and header are used they are worth less money than when new, a lot easier to trade a new one. That combo will only be as good as a muffler, but louder!
Old 12-03-2008, 07:16 PM
BarnacleNZ
ill jsut get the boat going for now. it not hard to shorten the pipe or turn it into a 105degree pipe. at least now i will know the reason if i can't get it too rev out well.
Old 12-04-2008, 05:25 AM
martno1fan
martno1fan's Avatar
Why cant you just get the right header from the start? there must be somewhere in NZ to get one ,you could have it in a cpl of days .
Mart
Old 12-04-2008, 04:50 PM
dicko
dicko's Avatar
There's a lot of shops in Australia that can ship one to you if you have trouble finding one locally too.
Old 12-05-2008, 09:58 AM
GATORl
Looking good //
