Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Insane mono Redline engine NFS steel pipe
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 12-20-2008, 03:35 PM
rcboateric
Banned
Default Insane mono Redline engine NFS steel pipe
Here's a few photos of my new Insane GerII and etc that was recently received, I will start building her next week, anyone who knows about how many trim tabs to install is the best for this 45" hull, please feel free to chime in, I'm going to install 2 or 4 trim tabs on her back even though the instructions didn't mention it.
ID:	1093238   Click image for larger version
ID:	1093239   Click image for larger version
ID:	1093240   Click image for larger version
Old 12-20-2008, 06:21 PM
Ron Olson
Ron Olson's Avatar
Default RE: Insane mono Redline engine NFS steel pipe
It's a matter of opinion on the trim tabs. Mine is supposed to be set up with 1-3/4" x 1-3/4" tabs on the outside and 2" x 2" on the inside but the person sent me two sets of the 2" x 2" instead. Some like split tabs like what Top Secret Boats sells.
Oh yeah, nice boat and engine so far! I've got a weakness for yellow boats.
If all else fails, ask Insane what they recommend.
Old 12-20-2008, 07:24 PM
rcboateric
Banned
ORIGINAL: Ron Olson
Thanks Ron, my trim tab size is 1-1/2" x 1-1/2", I have 4 of them, ok, I'll give Insane a call. Yellow boat is my favor...LOL
Old 12-20-2008, 08:03 PM
rcboateric
Banned
Here's the T-mod muffler, no leak flange and 2716 20* prop that I'm going to use.
ID:	1093502   Click image for larger version
Old 12-20-2008, 08:27 PM
rcboateric
Banned
This motor outputs [email protected] and [email protected] as the Dyno sheet shows.
http://redlinemotors.us/#/modifiedmotors/4522057162
Old 12-20-2008, 09:19 PM
brodjack
Hi Eric,something i've always wanted to ask; is the idea then to prop the motor at the higher HP for the fastest speed?
Brod..
Old 12-20-2008, 09:37 PM
rcboateric
Banned
Brod, I did run the same prop in my "Titanic" mono(it already sank in the pond..lol) and got 65.7mph, I don't know if it was a good speed for a mono hull or not, I know this prop is flighty so needed more than 35% CG to balance it back and may be need 4 trim tabs to do the same job too on my new build, this prop is also good for the cat, I'm sure it was the fastest prop for my Sprint cat in my opinion.
Old 12-21-2008, 05:38 PM
dicko
dicko's Avatar
Make sure you stuff this hull full of floatation. You don't wan't it joining your old hull.
I'm personally a fan of no trim tabs or turn fins if you can avoid them, I say run it without them & only put them on if you need to.
Old 12-21-2008, 06:11 PM
rcboateric
Banned
ORIGINAL: dicko
My old mono had no trim tabs install but it went a bit up and down and rock on between flat and choppy water, I don't have much experience to build a mono, had a few mono guys told me to use the trim tabs which is the way to go to resolve the issues.
Old 12-21-2008, 07:00 PM
glennb2006
Ken,
Not wanting to get into too much debate here, because I suspect I know how the outcome will pan out, however, here goes: nothing in the water that is not needed is the way to go for best speed, it is all drag you do not need. Put that prop into a box for hulls other than monos, and try to find a prop that gives good peformance and some stability. (That one won't on a mono).
Like everything, it takes time and some persistance lake side to find a good set up.
Try to build compensation for the bad attributes of surface drive as you put the boat together, and some adjustment to make it all work as easy as you can.
Have fun.
I'm out of here.
Glenn
Old 12-21-2008, 08:33 PM
rcboateric
Banned
ORIGINAL: glennb2006
Ken,
Have fun.
I'm out of here.
Glenn
Thanks for the reply Glenn, that's why I started this thread here about the trim tab thing, I know these tabs would create lots of drags but I would also like to see my new build run more stable and with some decent speed, let me call insane tomorrow for what's the best setup as they didn't recommend the trim tabs in the setup sheet.
Old 12-22-2008, 12:49 AM
nooh
nooh's Avatar
Looking forward to the build Eric, And also wondering about the trim tabs. Good Luck..
Old 12-23-2008, 01:35 AM
Justaddwata
Justaddwata's Avatar
Unfortunately Eric (Ken) is no longer a member of this site.
Old 12-23-2008, 05:05 AM
Hesco Racing
Reason being?
Old 12-23-2008, 09:30 PM
glennb2006
ORIGINAL: Justaddwata
Again. Not to worry though.
Glenn
