SIKK Coil
FL
Does anyone know what size the spacers are between the coil and the engine in a SIKK 25.4?
Was told they are the same as on a ZEN but still don't know what the thickness is.
NB, CANADA
ORIGINAL: savagecommander
they are much thicker than the zen spacers, id say three times as thick.
I was thinking about something totaly different.
Dan.
FL
Dan
I mean there are spacers on the two bolts holding the coil to the motor.
I don't know if they're metal or insulated and the thickness.
ORIGINAL: fuelman8
Dan
Dan
They are indeed metal, and are just merely stainless steel washers, nothing special.
FL
I put 2mm spacers between the coil and head and it still isn't running quite right.
Also when I took it apart there were no spacers and this was bought new. I can see where the coil dropped on the flywheel and left the mark where it had rubbed, when I install the spacers it brings the front of the coil out past the marks on the flywheel the 2mm distance.
