MOUNT question for CY26 owners
OK
I've done the search...but no mention of manufacturers/distributors specifically.
Need mounts...found many for Zen/QD etc...I'm mounting it in a Rio. Will any Zen mount work? Links...suppliers?
Also...anyone have a routing schematic for the 2 -in - 2 -out water ports? Bottom 2 in.....top 2 out? Just making sure....
Are there any pre drilled ISO blocks on the market?
With dual inlets, will I need two pulse fittings, or a splitter? Or will I need the 2 in 2 out pump from Bonzi?
This is getting more complicated....but fun.
John
John
RE: Question for CY26 owners
the pto side mounts are the same but the flywheel end is different, cc-racing sell mount for cy's
yes always bottom in top out
you don't need a water pump
OK
I did. Problem is, me being a gas rookie, it must say in black and white that it will fit a CY/SIKK, cause I dont know any better! LOL
I have looked and they all say Zenoah and or QD. The only ones I see that say Zenoah and clones (SIKK) are WHH composites, but the website is messed up right now. I shot Tony an email asking if they would work.
Thanks!
John
Thanks!
John
OK
I'm striking out here...O'Neill's does't have em, Daves DM doesn't have em, Tony doesn't have em...nobody has em. I've also looked at practically distributor every link in this forum, and the only ones I can find are at Bonzi, but you have to drill and tap the motor brackets....I'm not into all that....not to mention over 60 bucks...AND have to D/T...
John
John
FL
Its like jacob711 said....cc racing has them. Yes you do have to drill a total of four holes through the front plate for the two brakets....no biggie. Then just use nuts & bolts. You dont have to tap the holes. Thats how I did it on mine and it worked out fine.
RE: MOUNT question for CY26 owners
I've been getting my Sikk parts from Zac Price at www.americanrcboats.com .
Please don't keep editing your first posting as it makes things confusing for those of us further down or those reading it for the first time.
Do you have the stock Sikk motor mount? Use it. If it needs to be lower on the recoil end, a hacksaw will cut it down quickly. I hacked 3/4" off the bottom of mine to get it to set lower in my mono.
Just redrill the holes to make it fit, no big deal if you have a right-angle drive on a Dremel.
I'd avoid using the vacuum-operated water pumps too but if you insist on using one you can block off one intake and water exit fitting.
OK
Sorry guys....didn't mean to make it confusing....I only edited the title to say "MOUNT" so it would be more specific, and maybe get more visibility...
Thanks Ron, I checked that site, but the only mounts I saw were for Zen/QD. The mount that goes on the starter end wont work on SIKK, it has the 3 hole pattern for ZEN, or if it does, somebody please show me, I'd like to make em work if possible...
MD
is this what you are looking for.
http://cgi.ebay.com/Zenoah-23cc-Gas-...1%7C240%3A1318
OK
Actually I found a set marketed by Venom Group. They are for thier KWA26 which I've been told is nearly identical to the CY26. I've been assured they will fit, but I was going to wait until I got them installed before I posted any results.
here's the link...
[link]http://www.venom-group.com/storeitems.asp?txtkey=VEN-1848[/link]
They are on the way, and as soon as I try them out, I will post so others may know.
Those on Ebay look kinda heavy....
Cheers
John
here's the link...
Cheers
John
OK
Is the CY26 hard to pull at first? Even without a spark plug? I oiled the cylinder with some after-run, it helped some, but it is still very hard to pull over...
Just wondering if this is normal..
thanks
John
thanks
John
OK
That's what I wanted to hear!!
I kinda figured that, but being the gas rookie and all, I wasn't sure.
Thanks Scott!
John
Thanks Scott!
John
