Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
GAS OUTBOARD guys this is our new home
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 11-13-2013, 06:03 PM
  #2326
HendricX
HendricX's Avatar
Originally Posted by F1roddo View Post
I did have to do the double take on the last picture though,
my first thought was, "man, that looks so real ", then I read above the picture.... hehe
When Lex buy's a Wade-T leg , it would look more as 'the real deal' :-)
Old 11-13-2013, 06:39 PM
  #2327
specialk1
specialk1's Avatar
agree LOL
Old 11-14-2013, 10:27 PM
  #2328
Hesco Racing
Hendric you talking about the outboard that has only been a prototype for so many years. Probably one day we would see it run in anger.
Cobus
Old 11-15-2013, 02:23 AM
  #2329
YPC
YPC's Avatar
Howzit Guys !...wow !!! ...the boat's are looking GRAND !!!.....beautiful builds ! & beautiful Outboard Units - absolutely stunning !!!!
I have stopped producing the outboard legs and pipes for now - so it is great to see such great new OB products coming online
I have been out of the game for almost two years now !.....will be back next year launching a 1/4 scale F1 inboard fast electric class which we will be racing locally..A far less expensive set up ( simple strut and rudder) with more options of usage....
Busy building an OB for Kenya !!!!....first hull into Africa for me -amazing - sent boats to most every other continent ...except my own.
Other than that - still loving the surfing and building of the********s !!!!...
http://www.youtube.com/watch?v=hM-WMhJ1SmA&google_comment_id=z13mhls54xjjyjk04221cflopp2wipfte&google_view_type#gpluscomments Have a great weekend Guys !...and !!!...how about some actual RACING FOOTAGE !!!!.....if you don't race it....it don't make sense !!!
ID:	1939361   Click image for larger version
ID:	1939362   Click image for larger version
Old 11-15-2013, 02:52 AM
  #2330
YPC
YPC's Avatar
Originally Posted by specialk1 View Post
agree LOL
has to be the closest to 'The REAL THING'.....has the bigger unit have 'vertical lift' ? - I see room for lift on the pivot pin - used to run a VT system on a Nitro outfit of mine - worked awesome !
WELL DONE ON A FAB UNIT !!!!
Old 11-15-2013, 06:52 AM
  #2331
jpelezo
dominic, what are we going to do if we need parts for our ypc legs that we have.
Old 11-15-2013, 09:30 PM
  #2332
F1roddo
Thats if we ever see one up running on a hull. As Hesco said, its been in prototype for so long, might see it run one day, maybe ???
Cheers
Chris
Old 11-16-2013, 03:02 AM
  #2333
specialk1
specialk1's Avatar
that one i have their was the first prototype he made . the newer one has a better up down mid section that use a scale hydrolic system it has gone though many changes over the years . he has been slowly working out bugs in it . he stop working on it to focus on his scale v-6 project . when they will be for sale ???? dont know if ever ..
ID:	1939677   Click image for larger version
ID:	1939678   Click image for larger version
ID:	1939679   Click image for larger version
Old 11-16-2013, 07:13 PM
  #2334
F1roddo
Its definitely some outstanding quality craftsmanship, just a shame we haven't seen one running yet, would be a real head turner for sure.
Wasn't he also building a larger F1 hull to suit this scale outboard ?
Cheers
Chris
Old 11-17-2013, 10:06 PM
  #2335
Hesco Racing
The weight and complexity of such a v6 unit would not yield the same results as well modded 26. It is a beautiful engineering and machine job, but that is where it would stay. Would never become commercial. Now the leg at the other hand with some input from racers could become a nice venture but he has not taken it any further.
Cobus
Old 11-17-2013, 10:17 PM
  #2336
YPC
YPC's Avatar
Hi Joe - unfortunately !.....the global Gas OB demand in recent times does not warrant myself manufacturing further batches of units.
From my own extensive racing experience - you should only have to 'replace' the 'lead teflon bushes' every so often....all other components should hold up well...
In your case 'wanting the longer skeg' drive shaft assembly' - as with the upgraded legs - I am needing to machine up a drive shaft housing and slot it to complete the job...making one single unit is not viable.....
You could have a machine shop add S/S plate to you skeg to lengthen it - start with about 20 mm (4/5th") - that should do it...
As for the AMAZING SCALE UNIT above !......mind-blowing - an absolute labour of love - craftsmanship at its highest - however - as Cobus said - commercially - if AFFORDABILITY is not part of the equation It will not feature...
Old 11-18-2013, 03:47 PM
  #2337
jpelezo
thanks for info on parts. now, when you start up the electric tunnel will you be building parts then.
thanks,
jim pelezo
Old 11-18-2013, 09:13 PM
  #2338
YPC
YPC's Avatar
thanks,
jim pelezo
Hi Joe !
My plan with the electric F1 tunnel is to keep it as simple and 'affordable' as possible - SUSTAINABLE FUN- It will be an Inboards - utilizing the standard strut and rudder set up....I am wanting to attract a wider range of participants to the class - young and old / male and female - Electric is 'plug and play' - can be managed and maintained easier - I will be designing the set up around an 8s battery power set up - so that 4s batteries (fairly common size) can be run in series - keeping the expense down...
Looking to achieve speeds of around 80km/h.....anything over that will just make it 'to fast' for good racing......
Old 11-23-2013, 01:46 AM
  #2339
F1TUNNEL
Hi Dom!!
are you still supplying flex shafts for your ob lowers? How's that lower you've been working on for me going mate? I will send you a pm also,
cheers,
dion
Old 12-03-2013, 12:22 PM
  #2340
arraiano
Hello all
Glad to see you all here,well the South African guys are lucky now with summer,no visit these year,there,but boats here were also on the shelve started again but having problems with the setup of the Cat nosing abit cant get it to lift,but i also dont see many news here,Cobus with his boat was looking great,Dom,no new hulls from what i hear,also Latiff,Daz has a nice hull but the ducks also dont give a chance,like me running on salt water still havent found a place around here,
and looks like some new people also from SA well lets hear more from that side.
Best regards to you all
Joe Arraiano
Old 12-15-2013, 01:28 PM
  #2341
MTR35
well this will be my f1 tunnel for 1214 race year just starting on her. the leg is not mounted just seating there
ID:	1947709   Click image for larger version
ID:	1947710   Click image for larger version
ID:	1947711   Click image for larger version
Old 12-26-2013, 08:25 AM
  #2342
jpelezo
youngsz tunnel with arrow shark dragon drive. waiting on temp to warm up to test
Name:	arrow shark dragon drive 2.jpg
Old 12-26-2013, 09:38 AM
  #2343
Hesco Racing
With that leg hanging so far of the back I assume you have a whole nother boat stuffed in the nose to get the CG right?
Cobus
Old 12-26-2013, 10:17 AM
  #2344
jpelezo
had to a few more oz to get it to 27% , if it works ok will make a lighter mount.
Old 12-26-2013, 10:02 PM
  #2345
Hesco Racing
What made you decide on 27%. YPC's are normally build more to 30%. And with a lawless leg on the back the guys have to sometimes add as much as 500gr in the nose to get the cg right? Looks good though a bit big in relation to the boat. Good luck hope it runs great.
Cobus
Old 12-27-2013, 08:09 AM
  #2346
jpelezo
did not want to add any more weight that I has to. 27 works for me on our oval course. I still have water bag to use if needed. if I extend the cowl it might not look so funny. test mode first, then looks.
Old 01-26-2014, 06:27 PM
  #2347
rcmaniac6
My Feedback: (18)
Default Question for Dominic Young
Hey Dom, James Beasley here. Do you have any spare parts for your drives? Looking for 2 brass stuffing tubes for either the X Ray or the Enigma drives. Let me know please. email is - [email protected] Thanks!
Hi Joe !
Old 02-01-2014, 11:00 PM
  #2348
Johan1969
Hi I am new to this game can you please be so kind to tell me were can I get a leg like the one you have .I live in cape town and are waiting for the F1 boat to arive from Pretoria At the time I did not know there were guys building boats here in the Cape can you please be so kind to drop me a mail regarding the prise and were to find one.
I will be running a Zonah 29.5cc Water Cooled
Regards Johan
Old 02-02-2014, 05:57 AM
  #2349
Hesco Racing
Johan You can go to our website www.cmbc.co.za and on the contact us tab you can get our mail address and mail us.
Cobus
Old 06-19-2014, 03:53 AM
  #2350
YPC
YPC's Avatar
Change of pace !...
Took some time out to build my younger son a FE F1 Tunnel Hull...the hull is one of my YPC designs and products...
Very happy with the first launch - water grass was fowling the skeg on the leg and we still dont have th eright prop size..
https://www.youtube.com/watch?v=Diu8vM00FD0 Still to build the HVFE 1/4 scale !.....
Getting faster and faster .....really a sweet unit - handles better than it ever did with the Nitro set up !
https://www.youtube.com/watch?v=d1qx-BWzTt8
