Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
Proboat Hypersport 48
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 04-02-2010, 06:36 AM
MsDarla
MsDarla's Avatar
Default RE: Proboat Hypersport 48
ORIGINAL: spoolinaww
ORIGINAL: MsDarla
I had an Enforcer Magnum 57 with a M5 motor for a short while.
Pretty decent boat.
So you went from a WHH Mag 57 with a M5 motor mod to a Proboat and call the WHH boat ''decent'' !?
I'm shocked
[X(]
I was living with my mother who wanted me to get rid of everything,Few months later she died.
WHH 57 too heavy for me plus health issues.
The hypersport 48 fits in my car easily.
If all the drama and my health was better. I would still have the 25 rc boats I had.
I am adapting to my health & The space where I now live.
Old 04-02-2010, 02:38 PM
MsDarla
MsDarla's Avatar
1st run today.
Flex shaft came loose after 10 minutes.
Stalled twice.
Ran it total for almost 30 minutes and it still has half a tank.
Forgot to GPS it,My guess would be mid low 30ish.
Alot less noise versus the Shockwave 55 SS,Blackjack 55 and Enforcer 57 even with a proboat silencer on them.
Old 04-02-2010, 07:19 PM
bigcam406
wonder why the flexshaft came loose? i guess it takes abit for the engine to break in.low 30's isnt to bad ,i guess some tuning is required after break in.keep us posted.
Old 04-02-2010, 10:33 PM
Ron Olson
Ron Olson's Avatar
This is why when you get any RTR boat that you check every nut and bolt that you can get at. I've seen them too loose and too tight.
Old 04-03-2010, 04:55 AM
Enidz
Using a plastic balloon in the radio box is also a good way for the watter problem?
Old 04-03-2010, 06:45 AM
  #31
MsDarla
MsDarla's Avatar
Flex shaft might of came loose from me holding the boat still in the water while testing the throttle.
Sometimes I hold my rc boats partly in the water and run the throttle.
Splashing water around like a child in the tub.
Old 04-03-2010, 07:55 AM
  #32
misshydro
misshydro's Avatar
that still shouldnt have happened like that..I do hold my boats in water and throtle them up to see if there running rich or lean..like Ron said check every nut and bolts on new rtr's ,because most of the times there slaped together..
Old 04-04-2010, 04:08 PM
  #33
MsDarla
MsDarla's Avatar
2nd run today,Decent without stalling.
But the motor mounts on the left side came loose. []
Throttle cable glue came loose which I was waiting for since my other Proboats did the same.
Average speeds on the Garmin Forerunner GPS shows 35mph.
Overall I think Proboat did a good job on this one.
Old 04-05-2010, 04:54 PM
  #34
losifiend
Glad the boat is working out for you after the initial bugs. I'm a fan of pro boat as I have had 2 BJ26 boats and have never had an issue. Saw this boat at RCX this year and it looks awesome!
As far as the antennas go, I would of left them as they were. That's the beauty of 2.4, that you don't have to have the antenna, or in this case antennas, exposed.
Sorry to hear that some stuff came loose though, but that's expected from a RTR if you don't go over the nuts and bolts with thread lock.
I'm going to see what the Rio Z looks like before I make the jump to large scale boats, though I like the look of this better.
Please keep us posted!!
Old 04-12-2010, 03:06 PM
  #35
MsDarla
MsDarla's Avatar
7th run on the boat it over heated,I was running it slow through the water which might have caused the over heating. [&o]
The boat runs good and handles excellent but I would not recommend running the boat slow.
Old 04-12-2010, 03:53 PM
  #36
Justaddwata
Justaddwata's Avatar
I dont mind the look of the boat. Sounds like your having some teething issues with her Darla but that can be expected with plenty of boats out there.
Hope you can post some pics of her in action for us (video too if I can be greedy).
Old 04-12-2010, 10:25 PM
  #37
bigcam406
justa quick question,but how would you know if it was overheating.i understand that it is liquid cooled,but what are the tell tale signs? also,ive heard that the lack of ventilation from the cover has alot to do with them running hot as well.
Old 04-12-2010, 10:53 PM
  #38
Jon DesJardins
Get an overtemp sensor wired into the water-jacked and that will stop any potential problems....
Strange it overheated... doesn't it have a pump?
I would put some vents in the lid as well
Old 04-12-2010, 10:57 PM
  #39
Ron Olson
Ron Olson's Avatar
I saw a thread on another forum site where the author commented on the lack of air getting under the hatch and had to make some holes so that it could breathe.
Old 04-13-2010, 07:28 AM
  #40
MsDarla
MsDarla's Avatar
I noticed the sound of the motor has changed and smoke from the exhaust.Thats when I checked it right away. When I removed the hatch smoke came out.Melted a zip tie & throttle cable a little.
Old 04-13-2010, 06:17 PM
  #41
MrMikeG
Can you post a pic of the motor set up in the boat?
thanks
Old 04-14-2010, 08:12 AM
  #42
MsDarla
MsDarla's Avatar
Old 04-14-2010, 04:17 PM
  #43
MrMikeG
Did you notice your carb screws hanging out?
Mostly I wanted to see the throttle cable, I had one once that melted and stuck full throttle. Yours is different to my old set-up though. I would get rid of that idle screw to though.
Old 04-14-2010, 08:05 PM
  #44
MsDarla
MsDarla's Avatar
The insulator block is being replaced.
The throttle cables are too cheap. [&o]
Glued o rings to hold them,Mine always broke loose.
ID:	1418162   Click image for larger version
ID:	1418163   Click image for larger version
Old 09-02-2010, 02:14 PM
  #45
dude-
Thanks for the review.
