blown crank bearings on bj55
SD
took my boat out for another trial run tonight and the motor blew. took apart the motor and the rod bearing is gone. Where is the best place for zehona parts? Might look and see if i can put an echo engine in it.
CA
NJ
MO
RE: blown crank bearings on bj55
ORIGINAL: IMDMAN
SD
I have ordered up some new parts from gismos. really would have liked to get a mod motor but don't want to spend the extra cash right now.
I have been using synthetic oil 50:1 ration like it says.
MN
ORIGINAL: IMDMAN
well thats why you bearings went ... That not enough oil.....
8-10 oz. of oil per gallion of gas.
Where did you come up with 50-1? See attachment from page 6 of the BJ55 owners manual. 32:1 is okay for an unmodded motor in temperate climates.
ORIGINAL: IMDMAN
As already said. 12.8(10oz) - 16(8oz) : 1 oil- gas ratio is required for engines serving marine duty. They run at full power 95% of the time. The extra oil actually makes more power besides. Just because it is called 50:1 doesn't mean that is what a particular engine needs. Typically small engines require more oil than larger displacement engines hence the reason they list the different mixing ratio's right on the bottle of those 50:1 premix compatible oils. What it really means is it could provide protection at ratio's up to 50:1 if that was the particular engines recommended requirements.
SD
so what ratio should I run. I work on and sell high quality power equipment and it all runs 50:1 synthetic oil as do my snowhawks. I did not recieve a manual for my boat , but was sure i read somewhere that it should run 50:1.. please do get me on track. thanks Les
The information in my post above is copied and pasted straight from the BJ55 owners manual. Some like a little more oil. I live in a cooler climate so the standard OEM ratio works fine for me. Like Daniel stated above the load or duty cycle on these engines is significantly higher then cars or other uses for the engine. In short your paddle is always in the water getting her done! Find a deal on a stock Zenoah PUM260 and have fun. I wouldn't bother with a modded motor as the hull is probably not the best for that.
MO
Some guys use a name brand non-synthetic oil with 87 octane pump gas for break in (1 gallon). I personally use the samething at all times.
MN
ORIGINAL: Dockman
I do the same . honda HP2 comes in 16oz, bottle so I mix (8oz, HP2 to 1 gallon camp fuel) & run it like you stold it.
ORIGINAL: jtdesign
ORIGINAL: Dockman
yep...me too!
ORIGINAL: exotica
...arent all 2 stroke engines supposed to run 25:1 ratio? Im running mine at 25:1 without problems so far.
