Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Reload this Page >
problems on ideling
Speed - RC Gas Boats Discuss gas RC boats right here!
problems on ideling
Old 09-11-2010, 11:11 AM
mario 2982
Default problems on ideling
hi i have a zenoah G260PUM and its giving me trouble ideling cause it go's off !
and sometimes it knocks offwhen gas is pulled
is it a carb problem ? and how the carb should be properly mounted with the
bulb on top or at the bottom ? carb is a WT-644
can some help me please??
Old 09-11-2010, 11:37 AM
mistycreekboats
mistycreekboats's Avatar
Default RE: problems on ideling
bulb on top .... check and make sure everything is tight ... you have good fuel (Filter) .... carb may need new gaskets (diaphram )... or your seals may be leaking
here is a articule on carb tuning
http://www.modelgasboats.com/Magazin...uretor_Tuning/
hope it helps read it shows everything on your carb and how to tune it
Old 09-12-2010, 03:16 PM
panioul
And of course check your needles. WT-644 - 1 1/2 turns High, 1 1/2 turns Low is a good starting point
Old 09-15-2010, 01:47 PM
black talon
black talon's Avatar
i'm not sure but if there is a pulse port on the carb that needs to be aligned properly.
Old 09-15-2010, 01:49 PM
black talon
Old 09-16-2010, 04:09 PM
mario 2982
tanks guys you were very helpfull
