RCMK rear exhaust
Hi All
Just purchased a stock standard rcmk rear exhaust motor and want to know if any one can tell me some Mods for to raise the exhaust port timing etc I want this thing to go the best I can the competition in my home town NZ is tough |
RE: RCMK rear exhaust
It's almost the same as modding a side exhaust engine with consideration that the top-end is 90 degrees off.
This article might be of help to you, http://www.modelgasboats.com/rcmk-ss...-modification/ |
I have a stock K30 rear exhaust also...trying to get the best out of it. No mods yet, however it seems to have enough grunt to get to a competitive level. I think with the right prop it can be cometitive in heat racing.
What type hull are you using? |
I had 2 of the R-254's, still have one yet that's never been fired up. The first one was in a JAE gas 'rigger. The other I'd like to find a good hull for it or sell it, I'm not sure yet.
Gizmomotors.com make a top end kit for the K30RZ rear exhaust. Do the upgrade and that K30 will be putting out 7.5hp
I'm thinking that if I hang onto mine it would be a good candidate for a Gas Sport hydro hull, I don't have one of those yet.
Originally Posted by henschel
(Post 11583924)
the older RZ sufffered piston problems I run the the K30 rz topkit with only a couple of mods but left the sleeve alone and piston still looks good and plenty of power http://youtu.be/wgBhiieJF3w |
My goodness!!!Boating at Blenheim!! Way back in 1980 -82 i used to race at Picton, around the right hand side of the harbour. Twin Ops 65's in a rigger and a Prather deep V with i forget what.
Thanks for the memory jog!! |
