Help
My rc boat has a Chung Yang F273 gas engine with a Walbro WT 771 carb. Any ideas on a readily available inexpensive alternative carb for this engine. I did the rebuild however their is an air leak which keeps the bulb from pulling fuel.
Thank You c |
Walbro WT-257 or WT-1048. The problem is not necesarily in the carb tho. It could be one of the fuel lines or even in the fuel tank. Doug
thank you so much for the quick response. hadnt even considered the tank-just gettinf tired of it not running!
c |
