RCU Forums
-   Speed - RC Gas Boats (https://www.rcuniverse.com/forum/speed-rc-gas-boats-236/)
-   -   anyone running a Walbro 488 modded carb (https://www.rcuniverse.com/forum/speed-rc-gas-boats-236/5726389-anyone-running-walbro-488-modded-carb.html)
Shockwaver 04-16-2007 07:27 PM
I have a modded Walbro 488 what is a good starting point for the low and high settings i tried low at 1 5/8 high 1 1/16 with no luck then i tried 257 settings low 2 1/2 high1 1/4 still no luck seems to be flooding? Boat wont come up runs great with 644? Your thoughts?
OLD_SLOW and in the WAY 04-17-2007 07:12 AM
RE: anyone running a Walbro 488 modded carb
1 1/2 to 2 on the low side and 3/4 to 1 on the high side or just start turnin it 1/8th of a turn in on each run till it clears up and the plug is toasty brown
martno1fan 04-17-2007 07:19 AM
are those settings not the wrong way round shouldnt it be 2 1/2 high 1 1/4low?.i have a book for settings on the 230 and 260 rc car carbs which should be similar and the factory settings say 1 3/8 high 1 1/4 low so i maybe try those and see ?.from the sounds of it the low needle is too far open id go for 1 1/4 or 1 1/8 and lean the high out a bit starting at 1 3/8 and adjust a little at a time.
wayneuk01 04-17-2007 08:09 AM
http://www.bonzisports.com/faq.html
Q: What are the high/low settings for my carb?
A: Stock Walbro WT-644 carb
High = 1 1/2 turns
Low = 1 1/2 turns
Stock Walbro WT-603 carb
High = 1 1/2 turns
Low = 1 5/8 turns
Walbro WT-488 big bore carb
High = 1 1/8 turns
Low = 1 1/2 turns
Walbro WT-257 big bore carb
High = 1 1/8 turns
Low = 2 turns
Walbro WT-813 big bore carb
High = 1 1/2 turns
Low = 1 1/2 turns
glennb2006 04-17-2007 08:29 AM
I think it's pretty clear to see that thee is not an awful lot of difference between any of the carbs standard settings, as OLD SLOW and in the WAY suggested, get it so it runs (rich) then lean off both high and low from there in small amounts until you get it running as you need it to.
Glenn
martno1fan 04-17-2007 08:45 AM
it seems the low needles on some of those are way high as regards turns out(open)the book i have says 1 1/8 " thats from the zenoah factory .seems you read one book you get one answer read another you get a diff answer so best thing is throw em out and do it yerself lol :D.
glennb2006 04-17-2007 07:41 PM
Have a look here too, some reasonable ideas to get it right.
http://www.mpbc-act.com/Tuning_Zenoah_2_Stroke_Engines
Glenn
MrMikeG 04-17-2007 08:00 PM
Run the low rich, it gives you more power and it is a lot safer. The load on a boat is different to the load on a buggy.
Larry is one of the best sources for engine info on here! (aka old slow.....)
Minokiller 03-15-2021 03:49 PM
488 carb on qd 25
Would this be the same on a qd 25 hi rev
Minokiller 03-15-2021 03:50 PM
From like 2003
